1985 renken bowrider project
drexterm
pics of rotting stringers
pic of rotting transom
work started on the removal of rot stringers
stringers removed , grinding to start soon
Trooper82
Re: 1985 renken bowrider project
Nic start ya got going there!
Welcome to iBoats dry dock...
drexterm
thanks alot i am hoping to finish this project so i can have some more time with the family on the sea. Both fishing and recreational . anything you can offer to help would be greatly accepted ............... this is my first time around fiberglass repair
drexterm
man i went over the post on the project that you did with your boat ........ i am blown away with the support that you got with you project i must say that the individuals on this form are wise and helpful i am so taken back withthe help they gave you they are truely a wealth of knowledge to the lost ....ha ha i mean me . i have no idea what i am doing withthis boat as i stated earlier i never did this work before
i had to take out the gas tank the top is gone i also had to remove al of the stringers and the transom now. now the grinding ......one question how much grinding do i have to do .......also another question how do i get the stringers and the transom back in ............looking forward to help..............thanks for the welcome
drexterm
just finish doing some sanding however my grinders died on me they were old anyway let me know what you think
jbcurt00
?what?
1: How much grinding do you have to do to? On what?
2: Materials may be a challenge in the Bahamas. Read thru the threads here @ Don's helpful how to's. Read them again, it's not a small thing you are embarking on. Being in the Bahamas also presents a much larger environment for operating you're rebuilt boat, and a much greater change of encountering a serious situation out on the water. Everyone should be extremely diligent in how they put their boat back together, but the ocean & any big water presents much greater peril then my local reservoir. Read thru WoodOnGlass' stringer, deck & transom posts:
"Fabricating Decks, Stringers, and Transoms"
Read thru some threads in the resto section. There is LOTS of valuable information available to you already. Many choose to read & follow some rebuilds before they start major demo on a project so that they have some idea & direction on how to proceed in general.
As your 1st post had demo pix & no text, or questions, I'm not sure what the start of your last post I quoted is about, but my suggestions in #2 are a great place to start. In fact, Trooper's thread will have lots of helpful info too. Read his thread.
If you have questions, post them.... Many of the guys whose help you'll likely need, do still work for a living, and many also won't feel the least bit inclined to help if this very long journey starts w/ an attitude.:) There are a bunch of guys willing to help, give them a chance, there's only about 28000 threads just in the resto section, nearly 4 million posts total, and more then 370000 members. That's a lot of resources already available to you.
Now for the pix in post #5 you made, they pix didn't attach. Don's how to's have a how to post pix thread, while your going thru the rest, you might start w/ it.
How much access do you have to exterior grade (waterproof glue) or marine, auraco, okoume plywood in 1/2" or 3/4" thicknesses, and polyester resin, hardener, Chopped Strand Mat (CSM), 1708 Biax fiberglass cloth & acetone?
Welcome to iboats, patience in all things & post it w/ pix & they will come ;)
drexterm
thank you Jbcurt00:
You post is a great eye opener as referring to how much i was talking about how much grinding i need to d o i will repost the pics again i dont know why they didnt come out. i posted before and they did ..................indeed i have alot of food for thought as it relates to open sea and insuring that the boat is properly constructed i am presently following a rebuild dont by Trooper82.
it really amazing . i plan on posting pics step by step to get the most out of the very helpful and knowledgeable individuals on here.
yes i am able to get the materials that you listed but i am still in the preping stage now........... i intend on using the advice given as it is given from the knowledgable persons here .........thanks again God Bless
drexterm
another view of the wood attach to the bow section of the hull
on the port and star port sides
just notice that these two piece of wood just have a layer of fiberglass on it . is it suppose to be like this
grinding work done today
another view of the grinding done today
grinded into the gel coat because this section was really rotted out ................can 1708 3 lays be enough to do this
saginawbayboater
Was this a basket case? do you have the cap, interior, windshield, seats? What is the outside of the hull like? Does that have a outboard bracket?
more pictures are needed to understand your project!!
drexterm
i have a 1985 renken bowrider it has a omc sea drive engine 1.6 liter i think its a 115 hp will post more shortly
saginawbayboater
Oh Ok one of those sea drives. I have never seen the hull with the unit removed. Interesting!
drexterm
for some reason i cant find any specs of them as well it would help me alot with this restoration ...................i am fortunate to have individuals on here that are so knowledgable hope my pics come out well
drexterm
Jbcurt00
Thanks about photo bucket it a amazing tool to have the pictures look amazing ........... ha ha almost thought i was an expert there .............................i will post more on here and try yo upload the link in photo bucked as i take them ........
i am learning thanks for the lessons so far :D
jbcurt00
Look thru the parts diagrams for OMC SeaDrives:
here
Iboats SeaDrive thread
Thread discussion on another forum
And other iboats SeaDrive threads:
[h=4]reads[/h]
  • [h=6]2.7L OMC Seadrive Tilt & Trim Question[/h] By kameika in forum Johnson & Evinrude Outboards
    Replies: 0 Last Post: September 24th, 2007, 11:04 AM
  • [h=6]1.8 SeaDrive[/h] By raevin51 in forum Non-Repair Outboard Discussions
    Replies: 2 Last Post: August 30th, 2007, 12:27 PM
  • [h=6]OMC Seadrive horsepower question[/h] By creekster in forum Johnson & Evinrude Outboards
    Replies: 0 Last Post: June 27th, 2007, 11:07 AM
  • [h=6]seadrive 2.0[/h] By groundhogday in forum Johnson & Evinrude Outboards
    Replies: 4 Last Post: June 13th, 2005, 04:09 AM
  • [h=6]Twin SeaDrive install question[/h] By pdowning in forum Johnson & Evinrude Outboards
    Replies: 2 Last Post: August 8th, 2004, 05:30 PM
Old, and presumably obsolete, motor & drive parts & pieces can be tough to find. It looks like 1990 was the last year they were made. Any forum or parts place online you look for info, try to do a search for both SeaDrive & Sea Drive. Might find good info buried in any one of the sites that come up in a google search. And many many hits come up in a google search for either term: SeaDrive or Sea Drive. There is info out there, but it'll take several nights at a computer going thru the hits & seperate good helpful info from the rest.
drexterm
wow these post thrends are great ........ i hope when i start mine it fires as it use to thanks again
drexterm
good day everyone
i wasnt able to buy any other grinders but i was able to fix one of the ones that went bad .................so i am off to start some more grinding will post more pics soon..........................................wow i hate grinding it itches soooooooooooo much
drexterm
hi all can someone tell me if i need to remove these woods that are attach to the bow section what are they for
jbcurt00
Having no knowledge about your particular hull, speculation at best:
Blocking to support a toe kick like panel that ran across the deck under the bow. 'Dry' storage behind it. You can see the 1 that was in the bow of my FireFlite at the bottom edge of this photo:
In mine, it was primarily a depository for leaves & acorns :facepalm:
drexterm
ok thanks you are sure helping me alot i am on my way
cant wait until i finish this grinding it so itchie wow
