1983 Starcraft Islander
Mrshaund79
So ever since i seen one for sale and missed out I have been looking for a good fixer upper, i found a 22ft Hull is in good shape, appears to have been sitting inside, the add noted they had started replacing the floor which is what I figured I would be doing over winter regardless, but it has the 470, My question is are these engines really that bad or is it because they need to be properly maintained as most engines should be regardless.
I am looking for a budget boat to work on this winter and have ready for spring fishing and family time and figure this may be a good start and the fact I have always liked the looks of the starcraft aluminum boats.
redneck joe
LOTS of floor replacements on here that include Starcraft. Poke around and post pics of what you want to replace? Gets condiferably more in dpeth the farther forward one goes.
I'll defer the questions on the 470 to smart people.
Welcome to the forum.
bakerjw
Myself, I would go this route. A bit of structural work involved but in the end, the OB option is more desirable.
matt167
470 in that will scoot. BUT most 470’s are junk.. a good solid inboard 3.0L will drop right in and cost much less than an outboard conversion. 140hp is all that boat needs and what many of them got. However don’t spend too much.
If that boat ends up not being the one, you can add Sylvan Offshore to your list of contenders. Very similar hull built by an offshoot company of StarCraft. Built on the older style Islander hull essentially.
Shaunds
Yea I'm going to hold off I think and find one that's in running shape, I picked up a little 16ft for 500 dollars with a chrysler 105 to mess with until I find what I'm looking for as far as bigger
Shaunds
470 in that will shoot. BUT most 470’s are junk.. a good solid inboard 3.0L will drop right in and cost much less than an outboard conversion. 140hp is all that boat needs and what many of them got. However don’t spend too much.
Thanks for the tip, looking for something to fish the lakes and be able to have family days out and have always loved the islander as well as StarCraft in general
redneck joe
going to be tough to find one in good shape. they are all old
matt167
StarCraft built hulls for other companies as well as their own. Sylvan has ties directly back to StarCraft, but Bluefin, Spectrum and Smokercraft all had boats that StarCraft actually built ( not outfitted ). The Sylvan Offshore and Smokercraft Titan are basically identical boats, sort of loosely built on the older Islander but with a larger cabin. The “V” hull StarCrafts are slightly longer LOA and have a wider beam, but effectively very similar.
the 470 design was OK....ish, the execution was flawed
the good - aluminum block, high torque and heat exchanger
the head should have been aluminum - iron head on an aluminum block is just wrong.
the deck should never have been open - the bores move about a bit
the stator and regulator should have been a bit more robust
the cam snout should have had a speedi sleeve from the begining
for the deck and head issue, the solution was a larger heat exchanger. however one bit of debris to allow the temperature to creep up 10 degrees and the motor spit out the head gasket
you can weld in a deck stabilizing plate
you can get an aluminum ford FE head
you can do an alternator conversion
you can add a speedi sleeve to the cam snout
however the vertical imbalance of the motor has it trying to jump out of the boat and thru the hull simultaneously.
As Matt stated, a 3.0 is the common replacement. there is also the 4.3 as a viable replacement
