1980 Baja 180BR rebuild
Burglary5%
Boat.jpgHello all, I have been reading and reading on here for some time. I have learned tons and am ready to start my rebuild. I got a 1980 Baja 180 Bow rider last summer that I knew needed work. I could tell that the PO who said he had just installed a new floor just laid a sheet of ply over the old rotten floor, the interior was shot and the boat was generally a mess. As it happens none of that mattered as I love the looks of the old boat and when I look at it I see the finished product. I was able to take it out several times last year and would like to finish some time in spring if my schedule allows. I am very handy and have built houses and furniture all my life. I have already stripped the boat pulled the transom and stringers and ground everything down, I am ready to start putting things back together. I already have the poly, csm and 1708 from us composites along with the assorted rollers buckets cabosil and chopped fibers. I will take pictures when I can and add those. I just had a question that I can't seem to find the answer to, this boat is a balsa core hull and it is all in good shape. Everyone says that you need to bed the stringers in a 1/4 inch layer of PB or PL so you do not get hard spots in the hull. Does this hold true for a balsa core hull or does the balsa core act like the bedding? The stringers I removed were tight against the hull so I was just curious.I look forward to any and all comments and no I am not the sensitive type.
I will keep working on pics I am having some issues. Certainly not a computer guy.
Burglary5%
Re: 1980 Baja 180BR rebuild
The first one is what it looked like before taking it apart, the second is how i'm hoping I can make it look when finished, I like the simple paint scheme. I want different colors I'm thinking white on top and either silver or black on bottom. Unfortunately the metal flake gel is to far gone to bring it back.
bajaunderground
5%...
I have no advice on the fiberglass/pl/pb/stringer front as I don't think I'm there...yet? I'll leave that for the experts on here.
Good luck with the rebuilt, I too love the old Baja's, especially of the metal flake variety. Since our boats are similar, I will be following along (cheering when appropriate, of course) in anticipation of a quality job and a splash.
As you know, the masses here require lots of pictures and videos (boat porn, I have heard it referred to?) open up a free account at photobucket.com, upload as many pictures and videos, then post the IMG Code ...[IMG].
Ciao,
Brett
Burglary5%
Thanks for the picture info it was giving me fits. Feel free to chime in on any ideas right now the boat is a clean slate. As you can see the PO painted the window frame and the paint is coming off (looks horrible) I have that about cleaned up but will probably paint it again if I go black and white, he must have had some paint left over too as you can tell by the Johnson on the back. It's a 1973 135hp that after putting about $50 in to it runs great. I want the look of a merc like Baja's so I am on the hunt for one of those. I also love the look of your interior, my wife is a great seamstress and she has volunteered to make the new covers as I get the wood done.
Any ideas on the question of bedding the stringers? I dont even know that they have any structural value other than floor supports.
I am heading to florida for the week when I return the build will start and I will get pictures up.
Thanks guys.
This is what i'm going to try to get the back seat to look like I like the way it rounds out the corners.
ezmobee
Blasphemy.
evolution1985
Hey mate and best of luck with your rebuild, The main thing (other than the genuinely nice people) on here that I love is how simple it is to find great information. The mods here do a kick A** job on the stickys. basically if you need to do engine work, check the stickys at the top of the thread list, same as for your stringers. below is a great link that I have read far to many times.
http://forums.iboats.com/showthread.php?t=510077
That will answer any and all questions you have I should think.
Then if you want more information then OOPS is like the fibreglass guru, his build is seriously an adventure.
http://forums.iboats.com/showthread.php?t=234392
I would personally read both of those threads and then it should answer your questions on the stringers.
any question that I have asked so far has had great replies and helped allot, so you should be aok.
best of luck mate
Burglary5%
I found this forum quite a while back and have read oops thread from start to finish as well as frisco, wood arch and several others. I hope my project comes out as nice as theirs.
Sorry EZ had a merc on the family boat growing up and I guess it has stuck with me.
bajaunderground
5%,
I know this is kinda early in the process, but you can never plan too early for a repower...looking at the picture of your current motor, it looks as if it's mounted kinda low (at least from the picture, anyway?) I would recommend a jack plate (hydraulic if funds allow) that will get the motor out back more and adjustable up and down. I can't tell from the view, but your mid section might be smaller (mines a 20" mid and is mounted all the way down, I thought about raising it this summer and I have been looking for a used jack plate?).
Awesome that your wife's a seamstress (does that make a seamster?) if you make your rear bench in 4 pieces (2 sides, base and back) I would think having her make the vinyl would be pretty easy...when I get a chance, tonight I'll sketch up how I would recommend making the rear seat as to allow easy access to the bilge, tank and battery. BTW, I almost went that route and wanted to modernize it, but after seeing the cost of foam, I decided against. WOG's idea of using an old couch is a great one that I did not read until mine was done and installed!
Ironically, my 200 Blackmax is a model year 1980 (same as your boat) She was rebuilt about 5 years ago by a local guy...originally I had the 200 Mariner, but that gave up the ghost at about 65mph 7 years ago (Threw a rod through the side of the block).
~BU
Burglary5%
Baja- I will give the jack plate some thought, the motor was mounted to low but it had some up adjustment left I will have to check it out closer when I get the transom in. Believe it or not that is a 20" leg
Frisco- It is completely rotted out. the transom and stringers were mulch couldn't even use them for a pattern. Luckily the balsa core looks great so I wont have to replace that.
