The vinyl is up!!! Yeehaa! Lots of prep work went into this to ensure a nice finish, but it was worth the effort.
This is great stuff!
Here's the port wall getting applied,
And here it is on the wall,
Next was the aft wall and the back third of the starboard wall, which I put up in one piece so I wouldn't have a seam in the corner,
And glued down,
The rest of the starboard wall done,
At this point all I had left was small pieces of vinyl, so to avoid having a bunch of seams around the windshields, the Admiral picked up another 3 meters (3 + yds) of material. Around the windshields was the tricky part. Lots of compound angles.The dash is slightly arched where it meets the front, the windshield walls are sloped in at the top, and are angled in at the sides, so I made an empty beer carton template of the bottom edge, and cut the vinyl,
Everything is masked off and ready,
And here she is,
I ran out of stainless staples again, so I've got to resupply so I can staple down the rest of the edges before I install all the trim and moldings. It's gonna get fun now, I get to put the old girl all back together again!
I also finished off the bottom of the shower pan/washroom floor with a layer of 1708. I mixed the waxed resin with about 2.5% mekp, which kicked off nice in the cooler temps. I set it in the sun to help it along,
I knocked off the hairy stuff with the grinder and now she's good to go.
