Re: 1979 140 hp, fuel primer valve
I have had good luck with mine when starting cold by squeezing the primer bulb a few more times after it has gotten hard,basically trying to force more fuel into the reeds,fires right up that way.If your engine is a bit "worn" this procedure will work even better.Takes a while for the fuel to be drawn into the cylinder with older motors.
