1979 140 hp, fuel primer valve
stanfenn
1979 140 hp, this engine has a fuel primer circuit tha pumps fuel to each carb when a switch is activated. i need a new valve. got any ideas
thanks, Stan
79Merc80
Re: 1979 140 hp, fuel primer valve
I doubt that your Merc is a 1979 vintage as they still had the choke system. The enricher system began in 1982/83. If you post the serial #, then we can verify the year of your engine. Pictures are helpful as well.
Craig
stanfenn
the serial number is 5328223
thanks, Stan
Craig
79Merc80
It does come up as a 1979. Are you sure it has the fuel enrichment system or the choke system. When you push the key in, do you hear a click??
stanfenn
it has both. the bottom carb doesn't have a butterfly. the starter runs a long time when starting cold with only the choke. it has a automotive duel tank selector valve used backword from it's disign use. this afternoon I installed a motor driven valve used on modern trucks I just wanted to go to a factory system. the automotive valve is designed to be sucking fuel from one two tanks not under pressure and sending fuel to the carb bowls or to the priming system. hopefully this different style will work better.
thanks, Stan
mr 88
I have had good luck with mine when starting cold by squeezing the primer bulb a few more times after it has gotten hard,basically trying to force more fuel into the reeds,fires right up that way.If your engine is a bit "worn" this procedure will work even better.Takes a while for the fuel to be drawn into the cylinder with older motors.
