alipinski397
- Sep 3, 2013
- 63
Gauges and finding a spot for the Helix 7 was next.
Jason threw in those awesome Starcraft gauges with the deal so I definitely had to try and use what I could. I didn't want to lose the alarms built into the RPM gauge for the Ocean Pro going on it so I settled for using that stock RPM gauge and the other gauges i used those the black sterling series gauges. I still have a volt meter and a temp gauge to match and may think about installing those under the main switch panel in the future.
I set the old window up on the console so i could figure out where best to mount the Helix 7. I plan on replacing the Plexiglas window as the original is in pretty rough shape.
I had also refinished the teak trim pieces and had to throw set those in place just to see how it looked.
