ezmobee
- Mar 26, 2007
- 23,767
Re: 1975 Starcraft Mariner 18'
I'd want 8+HP for a kicker. Not sure on long or short shaft. Either would probably work but a long shaft might be nice if you're bobbing the swells. I love this link for showing an EZ steer type setup http://users.sisqtel.net/jkriz/Outrage/Kicker/ You may have room on the transom. I kinda do and I have a wider V4.
A quart size Gluvit JUST did my 18'. So you can probably get away with that (work from back to front).
I like this bilge pump http://www.iboats.com/SeaSense-Auto...0106585--**********.359092672--view_id.392307 built is float switch. Works on auto or manual. I put it in both the boats I've had. Get this while you're at it http://www.iboats.com/Seasense-Bilg...80106585--**********.359092672--view_id.56027
I used 3 gallons of epoxy on my deck. My wood was particularly thirsty. North Beach used marine grade and used way less.
