ezmobee
- Mar 26, 2007
- 23,767
Re: 1975 Starcraft Mariner 18'
Nothing wrong with electric shift. It was a fine system and when working, it works well. Problem is the solenoids in the lower unit that do the shifting and the switch in the control box haven't been available for a long time. So if it stops working, you're limited to ebay for parts. You also need to note that the electric shift lowers use a different lube than regular one and will NOT work right with the wrong lube. If it's running, I'd sell it as opposed to keeping it for parts.
The hardest part about doing your impeller will be disconnecting the shift rod. (and lining the water tubes back up). Otherwise totally doable and probably easier than my V4 was.
