1974 starcraft islander overhaul
dproctor1
Hows it going just purchased this 74 islander gonna do a complete rebuild on it for salmon and walleye fishing want something with a little more room then my other boat thinking of converting to outboard not 100% yet sure on that yet got lots of time to get it water ready still have the other boat to fish at the moment i noticed both fuel tanks are inside on the sides is there any way of replacing them if rotten or putting a tank under the floor also any way on to fix holes from old cover in upper half of the hull either way got lots of work ahead she needs a complete gut job added a pic of the islander
sidingguy
Yes on fuel tank.My 22' has a 60 gal tank under the deck in the middle of the boat .Good boat for big water fishing.
matt167
Yeah, the old tanks were made by Mirax and you'll probably find they might leak
Watermann
Welcome aboard,
Yeah those are cool looking Islanders, what I call the old gangster chopped look.
What drive set up does it have now would be the deciding factor in repowering.
dproctor1
Its got a 165hp mercruiser and pre alpha drive i believe hasn't ran in a yr or so cover got left off so its all probly pooched
classiccat
"Captain" + Starmada Splash Of The Year 2020
Welcome and Congrats!!
Nice big-water rig you towed home!
Lookin' forward of the destruction...err I mean deconstruction...and the rebuild.
I've seen alot of those O/B conversions started but not many completed.
Is this dock rash ...or a bullet hole 😬 🤣
dproctor1
Yea it definitely has some character to it haha that mark is a dent but from a picture definitely looks like its been in a shoot out lol.
Gonna take the outboard route on it just gotta find some info for how to make the hull strong from the inside to support a motor and kicker hanging off the back started gutting it today lots of room to fish compared to my lowe 12 feet compared to 6 ft of usable space from windshield
dproctor1
Well she's pretty well gutted time to pull the motor and outdrive this weekend and start looking at making something to tie the transom into the stringers
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Will be tagging along since Im ripping apart a 16’ SS and at a similar stage. Nice boat! Wish I had walleye around here. They are by far one of my favorites to catch and eat.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Not familiar with Islanders, but don't they have a knee brace or two?
SHSU
sidingguy
No knee braces in either of the two Islanders I have restored. One is a 191V with Sea drive 1.6 OMC and present 22 I/o OMC Cobra drive.
dproctor1
What was the make up of the motor mounts in those boats this one has two wood ones screwed to the ribs ill have a pic once I get the motor out
sidingguy
I/O boat had a wood 2x4 laid on a 2x4 which spanned 2 ribs on bottom of hull,Sea Drive unit attached to " bracket" on the transom.
SHSU
Interesting, so since the motor isn't pushing on the transom or supporting the weight no need for the knee brace. Learned something knew
(y)
SHSU
sidingguy
Having rebuilt a Holiday and a Mariner that had knee braces I was suprised at the lack of knee braces in the bigger boats.I suppose the i/o serves to spread the load over a larger area than an outboard.The same can be said for the Sea Drive unit .That bracket has got to be 12"x 20" at least.
dproctor1
Have you replaced the transom wood on an islander
sidingguy
Yes ,I have replaced the transom on the Islander with the Sea drive unit and also did a Slyvan 22' Offshore which is very similar to the Islander .That boat was a Mercruiser I/O.
sidingguy
The 22' Islander I am working on now has a good transom in it,which is a Mercruiser I/O.It looks like it was replaced recently,along with motor mount wood.
dproctor1
How do you remove and install the new transom wood is it replaced from inside the boat
sidingguy
Yes ,pull corner caps off ,remove aluminum cover over transom ,probably have to pull rub rail partially off. GO to outside of transom and start removing all screws and tiedown hooks,then pull transom wood out thru the top.P.S this is after pulling outdrive and pulling motor forward!!!
