Re: 1973 Starcraft Capri floor/paint redo
Ok I am still trying to get more pics up but my lap top has decided it doesnt want to recognize my phone anymore. Well anyway I have two new sync cables on the way with plenty more pics to come. I have completely taken out all the wood and foam I can with the cap still attached. There was foam under the floor in four spots in between the outside stringers and hull. I found that when removing that foam that about the bottom 25% was soaked with water still even being in a heated garage for a couple months which comes as no surprise. It appears they put the stringers in and then 1X2" supports across the top of the stringers then heavy weave. which from the last pics I downloaded you can see there was no protection on the stingers for 2 inches about every 3 feet. I am wondering when I put the new stringers in should I even worry about those 1X2 supports? I have read many threads here and watched most of friscoboaters videos and not sure these are necessary due to the new glass floor, stringers and foam.
On a side note is there a way to delete my own posts from this thread I started from when I was trying to get full size pics to post? When I try to edit it still says you need 3 characters for this post with no option to delete that I can see. Sorry the other forums (sports radio forums) I have been in let the user delete their own posts if they wanted to.
