Well here is my Starcraft! It needs floor & transom, maybe a fresh coat of paint come spring time? I am gonna focus on the transom right now. It has an 85hp evinrude on it now. Well not for long at least!
Welcome to the starcraft club Okie! I haven't seen a starcraft with an offset drain tube like that.
All the outboard versions I've seen have the plug off center like that. It's because the transom support is right in the middle.
It may not get the last drop out but works well enough there.
well here is a few pics of the transom tear down. Notice the transom support bracket! The previous owner did not use a transom saver so when the wood rotted it pulled away from the splash well and tore the support bracket tabs. Also the the splash well has about a 3" crack from the same trauma. I did not expect to be that bad, but hey stuff happens! The transom board is in 3 peices coming out but will be one solid when going back in. The motor is a 1975 85hp evinrude and i found is missing the lower gearbox drain plug. I hope i can get this motor back to a good state. If not i have a 1974 50hp Evinrude to take its place until i find another larger displacement.I am going to use this boat for mostly fishing but would not mind pulling kids on a tube if the fish are not bitieng. Well more pics and progress when the rains stops. Its suppossed to be raining all week.
Also i see the reason in the drain location but, leaving moisture trapped in the boat is never a good idea. Has anyone relocated the drain to bottom center? I will be installing at least one fill for my livewells in this area.
as for paint, almost everyone in the startcraft club has used rustoleum with the roll roll or roll tip methods producing good results. i think the only one that sprayed was north beach.
I sprayed my hull with a Wagner airless gun, and used a high pressure gun for the exterior gray trim stripe and all the interior. It turned out OK. Roll/tip works, but jeez, it takes forever. I finished my painting in about 3 days.
i wonder if ol' chip would do a boat??Well guys, she will get painted one day. However for now the transom and motor are gonna get all the attention. The whole boat is one of those " it ran when we parked it 3 yrs ago" . Which if I didn't know the people I bought it from I would have give a lower price. I tried to start it one day but I only had jumper cables to the boat no battery. So it barely bumped over so it isn't locked up. I have a very reliable outboard mechanic that will do that work for me.
Joey, I have your resto is bookmarked. Your boat is almost exactly as I planned to do mine. It may not be to the level of yours, it will please me. Once boat and motor are strong foundation I plan on the complete overhaul! I want to create a layout similar to the newer Starcraft 180.I just hope to have it ready by next memorial day. A large group of fisherman gather near my home after that. We camp and fish A LOT during 3-4days. Unless you starcraft guys want tocall chip foose and Overhaul it in a weeks time? LOL
okie, where are you located? do you know about tinstock next year? weekend of june 26th in lake anna, virginia if you can make it.
Andy, I am suprised you have to ask where! LOL, OKIES are from Oklahoma, BOOMER SOONER! Why june 26th is my birthday, may not make it to tin stock tho,
LOL Okie you know how them New Yorkers are . Good to see you got a resto thread going .
Rick
Well like I said I hope the 85 works out, but since I know the 50 is in great shape I would have no complaints of pushing 20-25mph just to get to the fishing hole. I do have access to a 115 rude but not sure if I need that big of a motor. I think the boat is rated for a 140? I could only imagine a 140-150 on it! Hello 50-60 mph don't need that!
.... Probably do away with existing padded seats and aluminum supports and start over to accomadate storage pocket, livewell and a rod locker. I want to install a ski locker as well. How did joey brace his for the lid? ....
