Re: 1972 19' AeroCraft Help Formulating A Resto Plan
Nice work thus far! For mixing, 5cc per quart is minimum, I used 10cc per quart, or 10ml per Liter.
Thanks parris, just to clarify though 5cc per
quart or
pint? I ask as I was mixing by the pint for this and thinking I should be using the 5cc line for a pint and 10cc for a quart as you say.
Here is a pic of the little measuring cup that came w/ the MEKP to show for posterity what I'm talking about on the markings.
You can see the 5ml-5cc line on the left compared to the 1/8oz line on the right. I will be looking at the cc-ml lines from now on.
With the exception of around the edges where I got the resin thick the transom has dried. Where it was thick is to the stage of being just tacky enough to show a finger print when you push on it. I got 6 screws out.
Oh well, guess I'll work around the other 40 er so.
Do I need to wait for this to completely dry before proceeding to wrap it in FG?
While drying it bowed up. The bow seems fairly even across the length, with it being roughly 1/8" at most along the bottom and 1/2" (maybe 3/4") across the top. when its installed the bow will be toword the bow. How big of a problem is this?
