jacobsladdergrice
- Dec 27, 2008
- 3
I just bought a used 15 horse mercury and winterized it this winter... I ran the gas out and then later thought it might be a good idea running some stable in the engine... yep ( you guessed it ) I ran it with out water! for around 30 seconds on idle....
Now after reading all the WARNINGS about not doing this...Im wondering if i should take the motor in and have the impeller and water pump replaced( the motor was 10 years old when i purchased it) It ran like a champ all summer. I just assumed that it would be ok to run it for a real short period of time with out water, and now everything i read states thats a big no no...
So my question is...should i just take it out next spring and see if she runs ok.? Take it in and have the impeller and water pump replaced?(might not be a bad idea anyway since its a used unit) Or do you think i may have done more damage to the engine? I did rev it once or twice but then just allowed it to idle until the gas ran out of the lines.. any help would be appreciated? thanks
