jasoutside
- Dec 20, 2009
- 13,269
Re: 1972 '18 SS Rebuild
Dood, love the Jeep! Had a CJ7 back in the day
Thanks Kev! I've enjoyed reading your projects.That triangular thing you call a skeg is simply a knee brace.
That's an awesome idea Glen. I already have one from the donor glass boat that's about the same size as the stock wood piece. My thoughts were to go back with the massive alum plate since I believe I'm pushing the upper limit on the motor size. Actually, I think blowing by the limit. There isn't a HIN or manufacture plate, but I believe I read on this forum that the limit was like 120 hp and I'm using a 140 hp.Just thinking with the number of holes you have to fill if you might be better off to put a piece of 1/8"aluminum over the outside off you transom with 5200. This would ensure it not leaking and would look good and be a lot easier than sanding all that JB. Just a thought.
Thanks again Glen! I started cleaning up the alum skin some yesterday. I'm assuming the white substance that I'm trying to take off is 5200. Has some serious adhesion!5200 would be the better product for the application for those reasons and I think stronger, I have found pl does not stick to aluminum that well.
Thanks barato2!CJ, i think later 18' hulls were rated for 140hp and it's the same hull
LOL barato. Understand that in TX the weather goes straight from winter to summer! This is prime fishing time and the plan is to have this thing splashed near the end of the May or middle of June. I know that's a very lofty goal so we'll see.OK, Senor "didn't get as much done as i wanted to this weekend"---you've gotten more done in a few weeks than i've completed in months on my holiday......
Thanks barato. There's only a 6 digit number that is legible so must be some state issued SN.if it ain't 12 digits, that pretty much settles it
Honestly I don't think this is an 18 SS hull, the cutout at the transom is not notched deep enough and there is no filler hole for a built in gas tank. Me thinks it was originally a 18 Mariner, which is a bit narrower and shallower than the SS hull and max HP would be 120
I don't think it's a 18 SS either. There wasn't a title and I was just going by what the boat salvage yard said it was. After running the reg numbers it came back as a 16' SS built in 1972. So max hp rating is 85...
