Re: 1970's 16 ft Aluminum Mackenzie Runabout Rebuild
Thanks Jig.
I picked up the rivets this morning.
I dipped the dome head into 5200 and inserted the mandrel into the rivet tool.
The first two attempts with three pumps and the mandrel broke-off leaving a hole in the center.
Third attempt was two pumps but the mandrel didn't break off.
Since the rivet feels set and snug I didn't think a good idea to attempt to break the steel mandrel. Instead I cut the mandrel top at the dome leaving a small nub.
The original rivets do not have an indent similar to the new rivets. I thought the dome heads were solid?
When the rivet is set I assumed the rivet tool would cut the mandrel? Perhaps I have the wrong size rivet? Tough to see clearly but the underside actually looks good leaving with 1/4 inch showing.
Thanks Jig.
