Just curious which method is better - rivets or self tapping stainless steel?
Yep, looks good J. Do you have the heavy duty rivet setting tool for the 1/4" dia. rivets?
I should have asked this earlier and maybe you've said somewhere in this thread but I've forgotten what kind of deck finish do you intend to install? If it's carpet, it will add extra thickness and those rivets may be too short if you plan to rivet through the carpeting too.
+1 on the Rivets there J. I also went the vinyl route but counter sunk mine so that the vinyl laid flat. Glad to hear you are going to bring the foam to level with the bottom of the floor.... it gives additional support to the floor --- surprising amount actually.
Bracing looks really sharp by the way... looks nice and rigid.
Jim
What adhesive is recommended to secure foam blocks to the center of the hull?
I am guessing that someone is going to say 5200 or 4200.
I have found the product pricey especially when the tube is partially used.
What other products are used to secure Styrofoam to aluminum?
I don't use anything.There's really no need if you're decking over it or building structure over it.It can't go any where and still provides floatation should the boat get holed or swamped.
Just mix and pour or spray the foam to fill the gaps along the sides of your slabs of foam, if you want to bond more foam on top of those slabs just pour or spray foam on top of the bottom slab and place and press the other sheet on top of the bottom slab like making a sandwich.
Thanks Jig.
I think someone else mentioned when all the Styrofoam is installed the pieces won't be able to move around much.
Flotation Material Installation Requirements
a) Air Chambers
Air chambers shall maintain their integrity under pre-test conditioning and under flotation test conditions. They shall not leak when subjected to an internal air pressure test and shall not allow the ingress of water when submerged to at least a depth equal to that required in the flotation test.
b) Plastic Foam Blocks and Other Shapes
1) A method of identifying foam blocks and other shapes must be employed to assure that each boat gets the correct amount of flotation in the correct location.
2) Expanded polystyrene foam must not come in contact with uncured polyester resin or fumes.
3) Foam blocks and other shapes must be secured so that no movement in any direction occurs that will effect the flotation's performance.
4) Installation must be in a manner that will prevent:
•damage from occupant contact
•deterioration from exposure to direct sunlight
•damage from normal use of the boat.
5) The space provided for the installation of foam blocks must be large enough to prevent the necessity of using force that will deform the shape of the block during the installation process. Deformation will lower the volume, and therefore the total buoyancy, of the foam block.
