classiccat
"Captain" + Starmada Splash Of The Year 2020
- Dec 20, 2010
- 3,409
Classiccat, I'm on page 60 of your rehab...it's quite the project! I'm in the process of ordering some 3/16" rivets and the correct rivet set. What length rivets did you use to replace the standard hull rivets without any patches and what was the length on the rivets you used for adding .080 patches to the hull. I have a feeling I'm going to be adding quite a few.
Good question MOd!
The general equation for determining proper thickness is: Length = (Cumulative Material Thickness) + 1.5xRivet Diameter
1.5 x Rivet Diameter is how much is sticking out. So if you're using 3/16 rivets, you'll want 9/32 (0.28215") sticking out. Then add the combined material thickness to that for your total rivet length.
You're going to want to have a selection of lengths. Going from memory, I ordered 3/8, 1/2 and 5/8 and that should cover just about everything. I may even have some 3/4.
Shorter stems are easier to set as longer rivet stems tend to want to curl-over on you.
When I ran out of the shorter sizes and/or I needed something in-between, I would trim longer rivets back based on how long the "bucktail" end we're starting with.
