FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
You want to figure out two things: which engine and which drive. Your drive could be Mercruiser, OMC or Volvo. Black is most likely Mercruiser, white is either Volvo or OMC. The engine is most likely a Ford or Chevy.
Photos of the drive should tell pretty quickly what you have there. There might be a tag on the engine telling you what model it is.
here are some pics. What can anyone identify here as far as make or size?
looks like OMC out drive?
Maybe Volvo motor?
the outdrive has a bolt hole on the top center. Is that for a grease fitting?
Bolt holes on the water jacket manifolds are for the drain plugs?
That's an OMC electric shift. In 1969 there was only one V6 for them Buick/Jeep 225. You should find a tag on the engine somehwere - typically rear engine mount - and it should read something like HUFM-69M
It's the old 3.8L/ 225. The same design team that built the 215 Aluminum block V8 did the V6 IIRC and some of the tooling is the same. Being a 1969 boat, the motor would have been aquired from Kaiser who bought the rights and tooling to put them in Jeeps and other industrial applications in 1967/8
Bottom line is, marine parts are long gone for that motor
