1968 Glastron V-174 Resto-Mod
Dangerwil
First coat of gel coat sanded.
sphelps
Looking good ! How many coats you think you’ll end up spraying ?
Dangerwil
I'm thinking five coats maybe more. That should finish base coat blue then flake.
My technique is very simple.
Coat number one 50% raw resin 50% gel, shot through a dump gun, mixed at 1% (Florida heat).
This fills most of the imperfections and keeps down pinholes. The resin I get from a place that manufactures fiberglass train bodies. It's a true laminating resin but it must have some kind of wax because after a few hours it has no tackiness. They go through a couple of barrels a day so it's always very fresh.
Let each coat cure minimum of 2 to 3 days.
Sand that off with 50grit on a da sander.
Second coat 50% duratec 50% gelcoat. Shot through a 3 mm tip spray gun 1%.
Sand it all off with 220 grit. Lather rinse repeat until all lumps and bumps disappear. I get a good film thickness and all the pin holes are filled.
Last coat gets sanded 320, 400, 600, 800, 1000 dry.
Buff with rag pad 1000 grit aqua buff then 2000 grit aqua buff foam pad..
Dangerwil
Headed down to Waldo yesterday to get some help from my buddy Jim. We riveted the wood on the side of the hull that the top cap will screw into. I put the top cap back on for traveling. Headed back around 7pm. A lot of the gas stations were already sold out of gas. Now we hunker down and wait for hurricane Dorian.
sphelps
Nice to have it inside with the storm coming ..
Do they still have the speed traps in Waldo ?
I know there was a big stink about that I saw on the news a while back ...
Hopefully the storm looses some of its punch before it makes it up here ..
oldrem
Another Waldo with speed traps?? Waldo, WI has been known for that for decades
Dangerwil
Unfortunately the boat couldn't stay in the covered Barn. But it's pretty safe on its pad here at the house.
Waldo used to be the worst speed trap in the nation. AAA bought billboards right before you got into town saying that it was a speed trap with giant yellow letters. A year or two ago the cops got fed up with the sherrif making them work ticket quotas and turned state's evidence on their boss. Entire Waldo police force was disbanded there's hardly any police presence there now.
Dangerwil
Got the next coat of gel sprayed on the boat. I had a few more runs than I was happy with but now the entire cap is blue. Some sanding a little touch up hopefully we'll be ready for flake.
oldrem
Mine is red flake on gray and still doesn't show up as metalflake in photos
