1964 Starcraft Jet Star Aluminum Runabout Project
  • Rustoleum Marine
    Votes: 19 41.3%
  • Interlux Brightsides
    Votes: 16 34.8%
  • Pettit Easypoxy
    Votes: 11 23.9%
  • Total voters
    46
ezmobee
Re: 1964 15' Starcraft Aluminum Runabout Project
I haven't had a chance to do any of these actual tests yet, but just thinking why would the fuel pump be bad if I drove it, picked it up a couple days later, then it just sat for a couple years? Could just be coincidental (it was about to go), but doesn't seem likely.:confused:
Because boats break when they sit. Not using it is the worst thing you can do for it.
Gibbles
I used 3/4" exterior plywood, glued together with gorilla glue, then sealed with epoxy resin & painted with Rustoleum marine primer & topside paint.
Thanks for the info.
Also for your steering, how long was the teleflex cable, and would you go longer or shorter?
Rghammond
After reading about your trouble I am now sure I am buying a new motor for my jetstar. I read all the fixes and my eyes start clouding over, way beyond me. Good luck, man, I've got all the faith in the world in you.
ezmobee
A used motor that is still supported with parts, has good compression, and has been thoroughly gone over by a mechanic will serve you quite well. Outboards don't die, you have to kill them. I have every confidence that LL's Johnson just needs a little tune-up work and it'll be good to go.
Gibbles
There is a guy selling a teleflex rack steering system in good cond with steering wheel and a 13ft cable that I have my eye on...
I think it might work, but there is a chance it may end up being to short...
lakelover
Yes, I went with the 13'. If anything I found it just the slightest bit long, but I think 12' would have been too short. With the 13' there is plenty of "slack" or "sag" in the cable on its way to the stern.
Gibbles
Perfect!
Thank you :)
lakelover
Well, the courier job did not work out, so I'll be back at the boat soon. Don't feel bad for me, it just was a real bad fit once I got an up close and personal look at the operation. I expect I'll keep an eye out for something else as time goes by.
jasoutside
I hear there is a boat building job in your area. Project on the roster is a Starcraft Jet Star. Nearly complete actually. The pay is terrible, hours flexible, and the rewards are fantastic!:D
lakelover
Ha, good one! It's not a pretty picture at "work". I'm sure the boat will calm me down. Hey, I don't need this crap, I'm retired!
GA_Boater
Too bad about the job, LL. But like you said - You're retired. So more time for things you want to do. I'm in the same boat as you. Retired a little over a year ago. Started to go stir-crazy. You just can't switch off like a light bulb. I was doing a fair amount of fishing with no boat and talked with the wife about getting a boat (well in this case I talked, she listened). So now got a SC to work on spending nickles and dimes and will be able to fish out of a boat again.
lakelover
Thanks GA, but like I said, no worries here. The not-working-out thing was really a two way street, bad fit for me and they wouldn't have been satisfied with my performance; and I didn't feel that they had given me a full picture of what would be involved, so in the end I thanked them and departed. No tears shed on my part.
Good luck with the fishing from a boat!
Rghammond
Funny how some work calms you down and some makes you crazy. Thank God for boats and workshops.
lakelover
Perhaps spray some pre-mix in the carb when it starts dying. If it picks back up you know you've got a fuel delivery problem. Also, if you try pumping the bulb when it's dying...if it picks up there then you know you've got a fuel pump issue.
Just wondering what you use to spray the premix in. And yes, it does recover when I pump the bulb. With both the stalling and no-oil issues, it would seem to point to the fuel pump. :(
ezmobee
LikfQjWyni7F2Uw11uoxagjhUJ55rEfmKTKJCI4nq3BGrmUKJiLO9QDmSOu4-fJe9_y11aRNE7obUNyLodHP07NMjLfJeAKZZXfjX1YgILye8TE8F5d7ruh8JpaxnpjXNp7AgJu_YF6VAbKH0gY0opIF_Q_OjNclnH56_pG89nYW-OcEwTgQl-Odo7NVwZ5IAPK2LFyH1A
Fuel pump rebuild kit should be fairly inexpensive.
lakelover
My die-cut vinyl registration numbers came today.
I got clued in to this guy on ebay by Jason in his thread & contacted him directly using the "Ask a Question" link. He does various boat graphics & numbers. I emailed him & asked some questions about registration numbers and he got right back to me, providing font choices and several color choices. After settling that, we did a deal directly & I paid him with Paypal.
It was $15 for two sets of numbers (free shipping) and they arrived in NY from California 4 days after I ordered them. A great guy to work with! Here's a link:
http://myworld.ebay.com/ebaymotors/shabestari/?_trksid=p4340.l2559
Definitely recommended!!
lakelover
Yesterday I got the bilge pump wiring problem sorted out & now that works OK. I put on the STARCRAFT emblems (thanks, North Beach!!)...you can see why I need the new rubrail insert. Once I have that taken care of, I can fasten the corner caps back on. Later this afternoon if it warms up, I'll apply the registration numbers.
I guess that makes it officially a Starcraft again!:D
jasoutside
Looking great lake!
Man, such a bummer on that rub rail.
I really think that ought to be black though if you can score some, eh? I think it would match that Johnson OB you have there quite nicely:)
lakelover
Looking great lake!
Yep, I guess modern rub rail is like the Model T - Available in any color as long as you want black. That would look good though.
Archie1212
Nice work! Is this guy where you bought your starcraft decals from too?
