matt167
Thread starter- Joined
- Sep 27, 2012
- 4,466
Re: 1961 Custom Craft Sea Ray Rebuild
I did some thinking and I have an idea to change it up. If I ground and added 1708 to the hull bottom and sides as it runs up the 'step' as a way to strengthen the hull, omit the bottom layer of plywood/ balsa or whatever. I could run 4 new stringers up the center and scribe them in relation to the actual deck height and subtract the thickness of 1/2" plywood from the bottom and cut them. Bed them up in PB, lay some 1/2" plywood to seal the decking, fill the cavity with 2 part foam. Tab the 'deck' to the hull using WOG's layup schedule, and then call it good. That's not the original design and It will add a tiny bit of weight, but not much. The hull weighed less than 500 lbs when built. I bet it was pushing 600 with the water logged foam. It should be stronger anyway
Only thing I have to do is make a clean slate, and of course carefully take apart the forward section rather than the mass destruction that happened at the back
