- Oct 25, 2011
- 25,344
Re: 1960 Glastron FireFlite has a new home!
To replace the rubrail, smooth aluminum (no rubber), I need to grind the interior fiberglass seam at the cap & hull joint under the gunnel. I had thought I needed to pull the cap, but I may spot grind at the rubrail bolts that are covered & forgo removing the cap.... With the bulbous fins extending past the transom in the back, I think 'glassing them from the inside since 'glass is fairly thin throughout, would be much easier to do w/out the cap installed. Now that I am less then 2 states away from the boat, I plan to spend some time with a grinder on her. She & I are neither 1 looking forward to it.
But that was why I bought the 36grit....
