1959 14 ft mckenzie tinnie runabout
Pixmith
Hey guys just starting a thread for a vintage aluminum runabout I just picked up and plan to restore. Please feel free to bomb this post with suggestions and pics
Watermann
Welcome aboard Pixmith :wave:
Now that is one cute little tinny you got there with great lines. :thumb:
Please tell me that you're not planning on ripping the bow open and making it into just another fishin boat.
fetch
jbcurt00
Might try Cherokee's too....
Welcome to iboats, and nice looking tinny
ssdale
Starmada Splash of the Year 2016
Congratulations! I rescued my 1965 McKenzie Cherokee Playboy from being buried for a goldfish pond. Scroll to the bottom of the "forums" page and click on the C section for Cherokees. I have some pics posted there of a 1959 brochure that was for sale on ebay.
​Onward and Upward,
Dale
http://
http://
ssdale
I'll be following along to watch what you decide to do with that beauty!
Luke000
Restoration Forum Splash of the Year 2016
Cool boat! And welcome to the Aluminotti! I'll be interested in seeing how your project goes along! It looks like it is in good shape to start and the enclosed bow adds a lot of character!
Pixmith
No Title
photo252415.jpg attach10275847.jpg hey thanks guys, I'm going to keep it as original as possible with only minor modification. I am an aluminum boat builder by trade but have never dealt with a riveted hull. All boats I build are welded. I'll have to make some decisions on rebuilding the transom to begin with. im considering building an aluminum plate with internal structure for the aft and interior sections that have rotted away. the other option im looking at is coosa board.
Pixmith
what rivet system do you guys recommend for repair work? air powered im guessing?
Watermann
For our Starcraft boats we use 3/16ths diameter brazier head rivets in a 2117T4 alloy for structural components. Air hammer with regulated air pressure and a brazier head rivet set.
Pixmith
Im thinking ill take a micrometer to the exposed rivet shafts and try to find replacements. ill look into ordering a decent brazier set soon.
Pixmith
do you use any washer on the back side of the rivets?
Watermann
The rivet shaft will be swollen from being bucked so I don't know how accurate that measurement will be. 5/32nds is another possibility but I would move up to the next size 3/16" if they were the smaller rivet. We also use 5200 to seal any replaced rivets below the waterline just in case as some of the holes become oblong.
oldhaven
I used Coosa for a transom on an 18' starcraft Starchief. If you decide to go that way I can probably give you some suggestions about how to use it. Short story, it is light and will never rot, works nicely, but is expensive and hard to source unless you are near a supplier. You would probably have to buy a whole sheet, but might have some left for other things. For a small boat you may want to use a very good grade of Marine ply and seal it well and it will likely outlast you.
Very nice project and you will take to rivets easily with your experience. They are a joy to put in unless you have touchy neighbors close by.
Ron
Pixmith
Just ordered the rivet gun and tooling. Found a local guy that will blast the boat with plastic media inside and out to remove leftover paint and grime, the interior is the worst obviously. I'm thinking after that I'll tackle the transom rebuild.
Pixmith
Also... Is it just me or are the mckenzie boats almost non existent!? I can't hardly find a thing for them or about them. Barely pictures or even the company name....
