Glued down most of the carpet on the gunwale and started riveting down the inside trim. This need to be done before I can install the consoles. Also have the engine removed so I can switch out the steering cable.
The front "U" shaped trim piece has a crack on it, so I drilled a stop hole on it before installing it.
There is some corrosion on this trim caused by staples in the bumpers.
This is a photo from my other Sylvan. The staples holding the vinyl at the top is resting against the trim.
