Re: 16' Nescher ski boat complete restore- SPLASHED!!
You guys are great....what should I put on there? Seats are totally trashed? LOL! Actually there are only a few cracks, with the exception of the bucket seats. For some reason those are worse.
TallCanadian he's right, 91 isn't bad...when its 105 I'm in the lake "hydrating" as you say!
Mick, Max is headed in for a check up Tuesday. I still have the ongoing voltage issue and I'm having him adjust the idle mixture. Max is loading up when he idles for a long time (Like no wake zones). A couple of the plugs did look a little suspicious, so that might help things too.
Today I'm going to try to figure out why the depth finder leaked out the RV antifreeze stuff. This sending unit has an "angle adapter" that you glue to the floor. After that you put a couple of ounces of RV antifreeze in it, then drop in the transponder and screw it to the adapter. The last day I was at the lake the depth finder quit working, when I pulled the plug, the antifreeze trickled out. David had the same set up with his, but couldn't get his clearances to work with the "angle adapter". He just took marine silicone and "glued" it to the floor. His works fine, has anyone else done that ?
I also need to find a new spot for the xm antenna. I have it mounted on the top of the controls right now, but when I rest my arm on the side of the boat it blocks the signal. So far I haven't thought of any good places for it.
I may also spend some time trying to build a few hidey holes between the seats and gunnels. I need someplace too keep my phone and wallet, so far they have just bounced around under the seat!
