[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Ted, it's a boat..... Fuel economy is never a consideration
jlh3rd
funny, seems like I remember on here someone posting that 3500-3600 +/- rpm seems to be that sweet mpg for most boats. It actually is for my pontoon.
nola mike
Performance update. . .
I have about 13 hours on the engines. I found a sweet-spot for fuel ⛽️ usage. 3600 RPM & 30-31 mph gets 1.4 mpg. So, that is a win 👍😃
The best I could do with the Mercruisers was 1.3 mpg.
If you go 100 miles/day every single day, you'll have paid for the conversion in only 10 years! (Winter too, no cheating)
tpenfield
Here is my fuel purchases this year for the boat . . .
I currently have about 55-60 gallons in the tank.
The Admiral get money off at the Stop & Shop Gas station for buying groceries. (y)
That stop at the Marina was painful . . . :eek:
alldodge
I don't keep gas records but I've filled my boat up with Reg twice (about 70 gal each time) and 50 gal's once. Price was 5.25 to 5.45 for 87 Octane E0 at marina. My tank is 123 gal
tpenfield
I'm keeping records this year, since it is a new engine and boat configuration.
Pmt133
The plant is basically an algae farm this time of year, been thinking about biodiesel... but I'm sure they'll find a way screw me on that too. Is government run after all.
tpenfield
Quick Update . . .
We may get to use the boat a couple more times, but our travel plans leading into the Fall will shorten our boating season.
I'll probably pull the boat in the next couple of weeks and do the following:
  • Check engine height and raise the engines
  • 20 hour servicing
  • Winterizing (easy)
I have updated my project plan, which basically maps out the 10 months of the project. Some of the fine tuning will happen next year when we launch for the season. (Probably early June)
Pmt133
I'm impressed with the sticker. I ordered the whole set for my truck. (14,000 pages) and they didn't give me a sticker. :(
tpenfield
Quick Update . . .
15 hours on the engine clocks. I plan on pulling the boat for its break-in servicing on/about Sept 14th. Hopefully, I can raise the engine a couple of notches then.
I ran into a little problem . . . :cautious: The fuel gauge, which is a Veratron VMH-14, is going from 40% to 20% (fuel remaining) in the blink of any eye.o_O . It has done this a couple of times, so I'm thinking maybe a sender problem.
Of course, not knowing the actual fuel level is a bit unnerving. The prior gauges were SmartCraft, and the re-power shop probably had to do some sort of magic to get the existing sender to talk to the Veratron (via 'easy link' :unsure: ).
Meanwhile, I guess I'll bring some more fuel out to the boat before the next outing. :rolleyes:
