[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
End of the season for me . . .
Trailer all set to go . .
The boat came on the bunks pretty much dead center.
(y)
Backing down my road/driveway was uneventful . . .
Lots of rain yesterday, so the boat had to take a pee.
Now for off-season maintenance. :unsure:
tpenfield
Just ordered my oil change stuff.
11 quarts of oil for each engine o_O + 2 quarts of gear oil.
@alldodge . . . my steering goes 4 turns lock-2-lock (30˚ pivot each way)
Pmt133
Everything seems to be 100 hours last I checked.
Typically the increased oil capacity is more to help with loading of the oil.... Most modern engines have larger sumps than I'm used to. My truck is 6 quarts. The GM LT V8s take about 9. Diesels are 5 gallons plus typically because of all the soot loading on the oil and allows for longer service life in the sump. I grew up with old crap so 5 quarts and a filter was normal.
alldodge
Verado is 7.4 quarts
Electric steering much better than hydraulic. Down side can you steer if pump doesn't run, found out by accident I can it's just hard
My Cummings 6.7 is 3 gallon of full syn and change every 15K
