[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
Where did the mercruiser #'s come from? ( took the V-P #'s and applied some magic, based on what I was seeing on my boat before the conversion)
scott's link looks like the VPs are closer to your current setup than the stock OB setup. Yes, I think the dual prop (Bravo 3) makes a difference in coming up on plane. thus the lines on the graph are closer. Sort of indicates that getting the stock OB version would not have been a good move as far as planing speed, etc.
Anybody have the skill to overlay all 4 graphs? No . . . :ROFLMAO:
Ted, do you have a GPH graph of your new setup yet? No . . . :unsure:
Also interesting on the VP test that there isn't too big of a MPG hit from going from 3500-->4500 rpm/ 30 --> 42 MPH
See comments above . . .
Those merc engines are interesting. They basically look like a gen 1 and gen 3 had a one night stand
It's more like a Gen I Chameleon.....
All GM Gen 1 parts inside a merc casted block and heads
Pmt133
I just realized the valve cover is an adapter plate. It really is mostly a gen 1. :ROFLMAO:
Wonder if the 4.5 crank will fit my 4.3. Another winter project. :p
tpenfield
Heading out to the boat this AM for some more running & data recording. Hopefully the info will determine next steps in tuning. Mike indicated that 5,000 RPM is the minimum and they shoot for 5,500 . . . 6,000 being the maximum.
Plan for the day . . . depending on sea conditions.. . .
1) Run at 4,000-5,000 RPM, trim up to the 75-90% range. See if there is any difference or sweet spot.
2) Use some remote cameras to get a look at the ventilation plates while running.
3) Get some fuel ⛽(maybe 30 gallons) and pump-out the waste tank.:poop:
4) Anchor near shore, drink some beers. :cool:
Pmt133
5500 makes sense, that's the rated speed for max power output of the engine.
tphoyt
It’s beautiful over my way. It was a bit windy early this morning but vineyard sound was like glass. Hope you find the same conditions.
tphoyt
I have a craving for fried chicken at 4:30 this morning. I’m going to take this as a sign that I need to make some fried chicken.
tpenfield
Wind is pretty calm
I did a quick run; got 50 mph @5300 RPM trimming up to 80%. $6.12/gallon for gas ⛽️. 🤮
I’ll try some more running on the way back from the anchoring spot (Bassett Island) 🍺
tpenfield
A little more choppy on the way back . . . but I ran the boat at 4000 RPM 35 mph. . . The display was saying 1.0 mpg, which may be suspect, because it does not seem to be using that much fuel. :unsure:
I know there has been some Internet chatter about Honda not calculating fuel usage correctly. :rolleyes:
alldodge
With a boat your size I would expect something close to 1.0 mpg, mine is half you size and weight a bunch less and my best cruise is around 2.3 mpg
tpenfield
I was getting 1.25 mpg with the Mercruisers, but outboards may not get as good fuel usage.
tpenfield
Overall, the boat is awesome . . . it comes up on plane easily and runs nice and flat. Being able to tilt the engines up out of the water at the end of the day is a real treat. :D
If we take the boat out tomorrow I should be able to get some video of the ventilation plates. (y)
tpenfield
After paying $6+ for gasoline, I am getting a fuel transfer pump. The Admiral buys our groceries at a local chain store that also has gas stations. You get fuel discounts for buying groceries. She typically gets between $1.00 and $1.50 off per gallon / 20 gallon limit. Much of the gasoline that I've already put in the boat was at a net cost of under $3.00 per gallon. :cool:(y)
. . . and the Hondas run on regular octane fuel. (86 minimum)
Pmt133
I took the old 27 gallon tank from the 4 winns and made it into a diesel transfer tank.
