New Journey
MNhunter1
Big milestone yesterday...got the motor mounted!
Also got my first mow of the year in, which had me looking at my mess of a garage... Figured with all the moving around I needed to do to get things moved from winter storage to seasonal use, it was time to get the motor off the stand and onto the back of the boat. The garage hoist made it a one man job, and the swing tongue I added to the trailer gives me the fit I was hoping for in the garage. I was a little worried I wouldn't be able to trim my motor all the way down on the trailer, but the slight tire size increase gave me just enough clearance. I'm at the top holes on the motor, so could always raise it a hole, but the cavitation plate lines up almost perfect with the bottom of the hull as it sits.
MNhunter1
Also got all the "spares" and "projects" tucked away nicely, aside from the extra parts lying around. Need to find a good spot to keep everything organized that's in pieces and not sitting on a motor stand...
MNhunter1
Wiring was a tedious process and I still have some finish work and wire management left to do, but everything works so far! I took a harness and cut off the plugs on the console side to wire everything in independently. Top mount controls, trim switch, ignition, kill switch, tach, water gauge, radio, speakers, switch panel(nav lights, courtesy lights, bilge, livewell, etc.)...it's all working. Still need to wire up my trolling motor/plug/Noco charger/breaker, but have two new group 29 deep cycles here and a new cable crimper, lugs, and 6awg wire. Looked at just buying premade battery cables, but it's always nice to have new tools and figured the larger crimper might come in handy down the road for other needs.
It's getting closer!
aspeck
Don't you just love it when a plan comes together?
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Man I need that winch system you have. I should have thought of that when I did mine. I used the old engine lift method.
SHSU
MNhunter1
Boat took a backseat to some needed landscaping projects and kid's activities, but managed to get the trolling motor batteries all wired up and the front deck in place. The end is near...just need to clean up some of the wiring and get everything buttoned up.
IMG_9721.jpegIMG_9722.jpegIMG_9723.jpegIMG_9724.jpegIMG_9725.jpegIMG_9726.jpegIMG_9727.jpegIMG_9728.jpegIMG_9729.jpegIMG_9730.jpeg
airshot
They are the Tempress brand. They have a few different sizes, colors, and options available.
My 1992 Sylvan has those same hatches and they are still going strong. An occasional wipe with a plastic restoring product and they still look like new.
redneck joe
thats kinda where I was headed as well. I also have two glove boxes I might install on the face, right next to the floor. That still leaves [i think] storage enough fromt he top but also give 'clean' storage as well.
redneck joe
don't forget to put the prop on before you splash....
What do you have boxed in under the helm?
I see you have the 12 gal under the seat, i did that as well as i've plumbed for a 6 under the front where you have the battery. My battery is on the casting deck under the bow.
lots more question but i'll do a couple three at a time
SHSU
How did you mount the trolling motor on the front? Looks like you used spacers to make it level.
SHSU
