1981 Springbok 18' Restoration/Renovation
SlipperyOar
They just use stainless wood screws, #14 I think. Pre drill the holes, and run the screws in. Trying to use T nuts would require way too much precision. You would have to dry fit the floor, take it back out, put the nuts on the bottom, and put everything back in without any shifting at all. They always shift a bit.
good to know, i figured it needed a bolted connection to hold the pedestal base secure with the forces exerted on it while riding. It's got 6 mounting holes so the forces should be spread out quite well. Last thing i want is for the seat to rip out from the floor. I've got 1/8" aluminum angle for the subfloor beneath 4/6 of the holes so if i add another piece beneath the last two holes itll be secured into the floor and subfloor.
MikeSchinlaub
Ensign
That sounds pretty good to me, as long as you don't drill the holes in the angle too big. Are the angles in the front pedestal holes? Those will take the most force from the seat pulling back, so they should have the widest force dispersal you can get.
SlipperyOar
the angles are beneath the front 2 and back two currently, but its a 10 minute job to trim another piece and rivet into the subfloor frame for the middle two. The big goal of this whole build was to make it a way that can be modified without starting over.
SlipperyOar
Had some extra time on my hands and haven't been able to get out in the garage to work on my boat so I made up these designs for my electrical switches. Going to use some of the remaining aluminum panels I've got to make these. I thought it would make the console look matched together being all the same style, this way the switches are all mounted evenly and i can neatly wire behind the dash with everything being uniform. Will update with pictures once I get these cut out and glued to the aluminum so i can cut to size and file the corners down to all be the same radius.
EDIT* with my livewell timer I was planning on getting a timer switch so it can run for 30 seconds and then i can vary how long it stays off, to conserve battery life. I plan on adding a 3 way switch beside the timer so it can run on the timer or manually. This way i can fill it up completely and then switch to the timer since I can't imagine 30 seconds will get it full.
83bluefin
You could simplify that a touch by omitting the timer and just use one of these to drive an air stone/bubbler…
Having too many aquariums running to count, your fish want oxygen exchange which happens when the surface is agitated. And these are USB rechargeable.
Or look into any of the bait saver bubblers for 5Gal buckets as they do the same thing.
SlipperyOar
Looks like a neat device but my livewell will contain fish that are heading right to the freezer or deep fryer, not much catch and release going on for the species im targeting. My livewell has a recirculation and overflow line in place to keep the water fresh/cool just until i get back to the docks and throw them on ice.
SlipperyOar
IMG_3480.jpegGot all of the wooden components cut to fit and the holes needed to rivet/screw/bolt into place done. The last things I’ll have to determine is the seat placement and where I need to drill holes. I’m going to be using 1/8” aluminum riveted to the subfloor and then the seats will mount to the plate through the floor to provide a bigger area to spread those forces out. In the meanwhile I’ve been using the OTF to seal up all the wood and then finishing off with a coat of paint for some added sealant. Waiting on my marine vinyl to be delivered so I can begin wrapping the pieces.
Once the seat locations are figured out and I get the backing plates mounted and holes drilled I believe I’ll be at the point where I can remove everything from the hull and shoot colour onto it. It’s been a long journey but the end is slowly becoming in sight.
SlipperyOar
Began wrapping the plywood in the Nautolex marine vinyl I ordered, super impressed with how well this stuff bends around the boards as well as how easy it it to work around inside corners and soft corners. Only the 2 main deck pieces to go but awaiting on some more vinyl cement before I get that done.
Also over drilled the seat mounting holes and filled with epoxy, used a 3/4 holesaw and then I’ll drill to 1/2” as it’s the size I’ll need to install the snap toggler bolts in place.
SlipperyOar
A little bit of painting done here, have yet to prime and paint the passenger console since I need to adjust the latch so the glovebox properly closes and holds so instead I did all the other interior components. Got 2 coats of epoxy primer shot on the transom and then have to spray colour, didn’t want to mix a small cup of grey when I can wait until I have more parts that will be grey ready to go.
Go lions!
SlipperyOar
Got the interior or the hull epoxy primed and shot the grey today, tomorrow I’ll be able to tape off and put the blue on. I’ll be officially done painting everything after tomorrow. Started attaching the hinges today, the bow pieces won’t be in until I put foam in the hull and finish attaching the subfloor framing.
SlipperyOar
Finally finished painting, a day later than I originally hoped to. There were some marks on the gunnels from when I had welded existing mounting holes up that left some warpage along with some grinding marks. I always wanted to do it once, do it right so I took the time Thursday to fill in all of them with thickened g flex 650 epoxy. Some only needed a skim coat, others needed a bit more filling, washing the amine blush off each time until I was happy with the result. Sprayed everything with more epoxy primer to seal it in and then shot the remaining blue colour. Taping the inside off to keep the grey, grey, was by far the most tedious job but I’m happy with the results.
Gonna install the transom when I next have some time to do so and get the bolts sealed up so I can pop it into the water for one last check to make sure there’s zero leaks. I’ve checked once already and it was dry but want to guarantee this before I start foaming beneath the floor and installing the flooring panels.
The last modification/fabrication I’ll have to do on the project will be involving the fuel tank. It’s currently got the fuel pickup pointing to the opposite end of the tank of the fill/vent nozzles. I’m wanting to rotate it 180° because the fill/vents fit perfectly to run up the side of the boat and to the gunnel on the port side but doing this would have the pickup tube always at a higher point while under way. I’m gonna give the tank a good soapy wash out and I’ve also considered running an argon purge through it when it comes time to weld the pickup nozzle back to the tank.
SlipperyOar
Got my fuel tank positioned within the stringers and at 75% of my overall boat length. I’ll have two batteries up in the bow deck for my electronics so setting the tank slightly aft should be the sweet spot. Used 0.125 aluminum sheets cut and bent on the brake to a C channel type of shape and then riveted another bent 90° to make it into a J for tons of strength to hold the tank in place. I’ll add pieces on top with more tabs to make sure the tank stays centred in the hull and does not move. Using nylon strips to bridge the gap where my supports/ribs contact the hull.
I plan to pull the tank out once all the supports are fabricated to clean, epoxy (any poultice corrosion), epoxy prime, and paint the tank to keep it as protected as possible.
SlipperyOar
Got the top cap of my transom installed yesterday, ran a thick bead of 4200 underneath it so when it got pressed onto the transom it should prevent any water from getting to the wood core. Fastened in with closed end blind rivets, each added with a dab of 4200 as well. Began putting the bolts in the transom for the knee braces and the trailer eye bolts. Tightened them down until it felt snug and I’m going to give them another 1-1.5 turns today with the sealant cured to really seal up the holes.
Hoping to hang the motor this afternoon but I need to cut a sheet of HDPE up to put between the transom and the bracket to give it a little extra clearance to not interfere with the knee brace bolts.
SlipperyOar
If the sealant has cures, don't turn the bolts any more. Twisting after it has cured could break the seal.
My plan was to hold the bolt steady and tighten only the nut (on the inside of the hull) to tighten it without breaking the seal on the head of the bolt.
SlipperyOar
Both sides should be sealed.
Yes they are, I carefully avoided getting 4200 on the threads where the bolt is and sealed the fender washer in place. As confusing and odd as my wording may have sounded I only had about 1/2 turn to torque them to spec. The bolt head itself did not move so the seal on the outside was never impacted.
SlipperyOar
Got the motor hung and bolted last night. Taking the weekend off from this project to tend to some other things. Hoping to weld a new threaded bung to the fuel tank Monday or Tuesday so I can get it pressure tested and then spray epoxy coating on it prior to installing.
MikeSchinlaub
Ensign
Ok, I get it now. It's just different than what I'm used too.
SlipperyOar
Launched the boat tonight for a leak test before I foam beneath the floor. Found 2 rivets in the bottom that had very small seepage. Maybe a teaspoon or two worth of water after 30 minutes sitting at the dock. Going to use some glu-vit around them with a syringe to seal it up and test again. Will rebuck the rivets as well. Overall very good test launch.
