‘91 merc 60hp overheating alarm buzzing
Evinrudej
it’s not looking like it has one just connected to block no head or am I wrong ?
Evinrudej
My service manual for 100 hp range 2 stroke Mercury's says to expect problems if compression is less than 120 PSI. You're close and it may be ok but the manual says what it says!
So I had a feeling my compression tester wasn’t reading correctly. Bought a new test and tested today
(after running for 5 mins)
Top- 126
Middle- 130
Bottom-125
Generally speaking, compression testers are often inaccurate. However, they are usually reliable. If all the cylinders read the same (within 15%), the compression is good. I think your numbers are just fine, despite what the manual says. Is that a Merc Service manual?
Texasmark
Mine is.
