2014 GMC Sierra AC
so, the 2014-2015 GM trucks have a couple of known AC system issues. first issue is the original designed condenser cracks.... and leaks..... this was replaced a few years ago.
the second known issue is the A/C compressor locks up, usually explodes and has the glitter fairy visit the condenser, filter, and evap valve..... then you need to replace most of the system and clean the evap coil, lines and all the components.......
so on the way home yesterday, tooling along in a 30mph zone in 99% relative humidity on a 95F day...... a loud bang followed by what sounded like my ex wife going thru a wood chipper....... the smell of burning rubber and a cloud of rubber bits and smoke...... no more AC
luckily the broken belt got tossed to the side where it did, or it would have taken out the other belts
local dealership wants $1992 in labor alone, plus about $3k in parts
two local garages want about $2k total for the work.
If I do the work myself......and borrow the neighbors vacuum pump
Rock Auto is $665 plus shipping
Amazon is $830, however may take 3 weeks to get the parts
estimate about 2 days labor to R&R everything prior to evac and fill
good news is I get better fuel economy right now.....
the bad news..... going into a heat wave and have a 1800 mile round trip coming up.....
dingbat
I feel your pain.........the AC in my Civic has been down since Mid-May.
Fortunate in that my commute is all highway miles and the 2-80 AC still works. Broke down and drove the truck on the 100F+ days
Procrastinated enough. Dropping it off at the shop Sunday Night
Bummer
Don't forget about flush, receiver dryer and expansion valve
have a flush canister coming from amazon. (with regulator, nozzle, and stainless tank) talked to my bud who is a chief engineer at a commercial AC/Refrigeration company about flushing with acetone. he said just run the vac pump about an hour vs half hour to make sure its gone. it will work better than the cleaners. also have some of the four seasons cleaner coming.
just did a mixed order from Rock Auto and amazon. balancing shipping/lead time/part cost. Parts should all be here mid week. Heading to Tractor Supply to stock up on freon this weekend.
have a new cam sensor coming for the daily whip to get that back on the road.
……a good time to consider renting a car!
that wont happen. dont like anything they rent (or make) these days - too boring, too many restrictions. will be getting the daily whip back in service this weekend.
southkogs
I had to rebuild the Mustang's system this year. Wasn't too bad, but it wasn't a newer full-size truck either :unsure:
Sprig
My 2 cents worth. Have the work done by a pro (not the dealer whose prices are way way more expensive than anywhere else.)I’m a pretty good shade tree mechanic but I don’t do a/c. I and most everyone I know don’t really know much about a/c repair. Most people I’ve known screw up the a/c repair every time they mess with it. You need someone knowledgeable and experience. Find a shop with an experienced pro. Perhaps you are knowledgeable with the a/c and know what you are doing. Though it sounds like a major undertaking, think I’d rather drink beer.
AC systems are easy. If there was freon left, I would consider having it reclaimed.
I do wish I had the larger AC service cart /vac/etc I had access to years ago vs a small vac pump
Dealing with damaged parts from Amazon is the biggest PITA
Pmt133
I did the vette a few years back and so far so good. I went from a tube and fin to a parallel flow condenser (R-12 to R-134a conversion) and with the top off the damn thing spits ice cubes at me. I did use a flush which, I am pretty sure was just toluene. purged with nitrogen vacuumed and let rest over night to check for leaks.
That era truck is still R-134a correct?
Amazon has a replacement condenser coming on Monday.. I hope it arrives undamaged
GM Denso compressor and belts showed up today. just waiting the expansion valve kit (with seals, and desiccant bag) and the GM PAG oil.
start R&R tomorrow if the temp is below 94
matt167
I think 2014 will have the stretch belt. You’ll need a new install tool if you don’t have one, and a 24mm w/ breaker bar to rotate the engine.
If you haven’t done a water pump lately I’d recommend it while you’re in there.
Both the vac pump and AC compressor have a stretch belt.
My personal favorite stretch belt tool is 2 zip ties and a remote bump start switch. One zip tie around the damper to act as a slide, one to hold the belt. Bump the switch twice, then cut the zip ties. However I have done the 24mm/breaker bar and a bit of swearing
Will address the water pump when it starts to leak
Plugs are on the list as I did the last ones at 65k, and there is 126k on the clock
So Amazonsux dropped the ball. The replacement condenser that still says its arriving today, also says it hasn't shipped yet. So 1 hour with 8 different customer service folks in pakiglesh or banglastan..... I get the refund for the unit I returned and a credit to use on another one.
Amazon roulette.... Will 1 or 2 or 0 show up tomorrow?
well, the replacement that Amazon supposedly sent on Saturday still has not shipped. the one I ordered last night shows it shipped and is out for delivery.
and people wonder why I am constantly muttering "amazon sucks"
To top it off, I am chasing a fed ex package that has been sitting in belle Island Florida since Saturday.
