Bravo 3 loss of lube oil - slowly then rapidly x2
dubs283
Light heat around the snout/housing with a map torch along with light gear oil inside and around the bearing races/o ring will aid install
2 4 C is okay, better yet would be extreme grease in place of 101.
Once the bearing assy is seated, grease the threads of the retainer ring prior to install and final torque
gcarmich
I saw someone remove the fork rod with a threaded rod andwasher/nut. Any idea what thread is on the rod?
gcarmich
She's aligned, back together, and holding 10psi.
Before I reattach to the boat, is there a way to check to see if the shift mechanism is working properly?
