Volvo Penta exhaust riser
Blake0192
Hello I have a 2003 Volvo Penta 3.0 I just put a different motor in my boat bc my motor was locked up. on this new motor I have a black hose off the exhaust riser that I didn’t have on my old motor can I just put a plug in it?
What is the other end connected to?
Salt away is a tee in the raw water line, back to a glorified windshield washer reservoir. Doesn't look like a salt away / neutra salt installation
Blake0192
It wasn’t connected to anything I bought the motor from a guy I believe it was connected to the lower unit. I plugged it. Let it run for about 30 minutes. It seem to be doing fine.
dubs283
Only time I've seen a line like that from the exhaust cooling passage is for a dripless propshaft packing on an inboard/v drive or a hot/cold raw water shower
It'd be best to abate the barb and hose and just plug the hole
Blake0192
Thank you
ta79pr
Page 463 of the Volvo Penta service manual shows the 98 model of the 3.0 has a hose to the riser from the thermostat block.
Fun Times
ta79pr
To add to the puzzle, it appears Volvo was making some various configurations for the 3.0 during the 90s. Here is the color cooling diagram, shows a version of the hose from the riser but this time to the exhaust itself.
ta79pr
And then a version plumbed to the steering cooler (mechanical or power). Good luck, interested as to which is most correct for your application/swap.
