Help with prop?
coachkwj
I recently bought a 2018 18' pontoon boat with 40 hp Yamaha 4 str. Boat hits 15 mph at 5000 rpm full throttle. Full throttle can be 5500-6000 rpm. Current prop is 11 3/4 X 9. Any thoughts on a different prop for better top end without over revving?
alldodge
Don't think you will get much better top end
Could go to a 10 pitch if you can find it, but don't think it will be much better
jlh3rd
Ensign
you understand that you are 500 rpm below the minimum of 5500. You are lugging your motor.
coachkwj
So should I go with a 10" or 11" pitch?
I checked the prop again and the diameter is actually 12 1/4", not 11 3/4" as I earlier stated. Does diameter have a big effect?
Thanks in advance.
You are already over propped. You do not want to go up in pitch
jlh3rd
Ensign
Thanks in advance.
no...you are overpropped as stated.
to increase rpm you reduce pitch, or diameter, or # of blades.
yes, diameter plays as much a role as pitch.
So, you go to an 11x8....or 11 1/4x8...maybe get 5600-5700 max rpm, maybe more...might be less...
see what happens.....but you want to be no less than 5500@max throttle...
propping a boat is not exact science. and can get expensive...
if you want a better top end, you need more motor, or your current motor is at the wrong mounted height.
I would suggest looking to see where the cavitation plate is while you are underway. you may need to raise the motor.
