Texasmark
- Dec 20, 2005
- 15,061
I guess I need to re-read my fluid dynamics Physics books. I recall just the opposite. Agree on the other subject you mentioned being suspect. At least he is dealing with a new engine so one could eliminate that. Having had another engine installed and assuming that he maintained his transom height dimensions, with the essentially flat hull at the transom, that should not be a problem.
I find this totally confusing...from his first entry......."The 21P was chosen because they did a sea trial with a 19 and said they could not get max RPM. Now you can get max RPM I just feel speed should be higher."
A 19P is lugging but a 21P gets max RPM??????????? Something is definitely amiss here!
