Multi function display
wirenut75
Hi there. I've got a 2017 Tohatsu 115TLDI and I'd like to add a multi function display in order to read engine data. Does anyone have any recommendations about which display works best with this engine?
I called Tohatsu and asked the same question but they were reluctant to recommend a display other than their TOCS display, which is nearly $1000.
Thanks!
dingbat
Thanks!
Not a bad price at all if it’s plug and play. Otherwise you need a Gateway plus a Display
The “best” MFD depends on what functionality it’s required to support. If your intent is only engine gauges your probably better off with a digital gauge package from the manufacturer
Most Depth finders running NMEA2K can ve used as an MFD
Agree above. $1k is cheap if it's plug-n-play
wirenut75
Thank you for the responses. If the MFD was a combo fish finder I could justify the price (in my mind 🙃) but I only would like engine data.
I did come across this: see picture.
dingbat
It would work but looking at the docs its does way more than basic engine data.
I would be concerned with the "ease of use" of the HMI interface. Not a fan of "push button" menu structures
