60HP 1989 Johnson outboard low compression
Toshi
The assembly grease will help you keep the needle bearings in place durning assembly.
Without it you may end up going insane.
Thanks. I bought used used assy. (piston and piston rod already assembled). I didn’t need to assemble needle bearings.
Toshi
+1 to this.
It is incredibly difficult to keep needle bearings in place for assembly without it.
I recommend putting the stuff in refrigerator and assembling in a cool room.
+80 degree F temperature melts it rather quickly into liquid if not refrigerated.
Make sure you pay attention to the connecting rod lube hole orientation so it faces upwards towards flywheel and that the piston is put on correctly facing the right way.
Thanks. I will check the orientation of the assy. (piston and piston rod already assembled because I bought used ones on eBay)
havoc_squad
The connecting rods can be re-used if the surfaces are good, within tolerance measurements, AND the connecting rod caps align properly without an exposed lip/groove.
However, you should NOT re-use used pistons that you got because they were tied to connecting rods that you had to buy.
So if cylinder 1 piston is junk, you replace it with new piston, ring, and wrist pin.
If cylinder 2 piston is good and is 100% verified as not needing replacement, you re-install it ONLY in cylinder 2. You do not use that piston for anywhere else.
Toshi
Thank you.
I ordered new piston but the pn on the piston arrived says 433945 and not 394461. I did a bit research and some say they are equivalent and I’m checking with the store that I purchased I am not convinced…
Any comment??
Thank you.
Toshi
Thank you.
Any comment??
Thank you.
The height of the piston is different. No way this is equivalent.
Toshi
I am trying to put crank case back and I noticed the bearings on both ends of crankshaft don’t fit right.
I see some gaps as shown in the pictures. Can anybody help me out why this is happening? I keep rotating crankshaft but I get the same gaps. Thank you.
Are you lining up the split bearings and dowel pins ?-----Work carefully and don't use a hammer.
flyingscott
That is because your center bearings have holes in the races. These need to align with the pins in the crank case, then the crank will fit correctly.
Toshi
They fit correctly now. Thank you very much !
Describe how you installed / torqued connecting rod screws.---And how you checked alignment of the rod caps?
Toshi
I tightened the connecting rod screws little by little making sure the side edges of the mating surface are smoothly aligned. I followed tightening torque according to the service manual.
Toshi
I am now struggling to remove the reed valve bolts to replace the gasket. I torched and put penetrating oil at the bolt, but no luck even with manual impact driver.
I will try with automatic impact driver to see if bolts come off.
If you have any advice, please let me know.
tphoyt
I know it’s sounds crazy but use the hand impact to tighten just a hair to try and break the grip. Like try to tap and twist forward and backwards.
Toshi
Thank you. It worked !!
Toshi
It’s been a while…and finally she is back and runs. BUT, it’s running rough.
I will tune air-fuel mixture screws (because I turned some long time ago with my ignorance and I didn’t record the original position…) but do you have any recommendations what to check other than these screws?
Here’s a short movie hoping this would help for you guys advice.
Thank you.
  • IMG_2879.MOV
saltchuckmatt
Thank you.
Are you running it without water?
