nola mike
- Apr 22, 2009
- 5,852
Looks almost stripped. Use an impact driverI am trying to remove bellow house from sterm and I failed to remove the screw at the last step. How can I remove the screw.
Ok. So I can just cut the wire off. then I can continue work on it
How can I apply this set? Could you please send me a link in youtube? I have found this set in Canadian tie.
Only recommended manuals are the MerCruiser factory ones. Put the serial number of your engine and the serial number of your drive and we can tell you which manual to get.
How can I removed the shift cable?
Here you go... Most of the questions you're asking are covered in the manual. Tools should not be your first priority, the manual should be. How do you know which tools to buy if you don't have the manual to help you decide how a job should be done and which tools are needed?I know that manual #6. But first thing is buying some tools.
Cut it if you're going to replace it.My neighbor has successful removed stripped screw. LoL.
What should I do if I do not want to replace it? it works. I should do something on the engine sideCut it if you're going to replace it.
Before you remove the shift cable, tie a length of line to the engine end to make sure you have a way of getting it (or a new one) back in the right path!What should I do if I do not want to replace it? it works. I should do something on the engine side
I need to rebuild bellows house.Before you remove the shift cable, tie a length of line to the engine end to make sure you have a way of getting it (or a new one) back in the right path!
Have to ask, why are you removing the bell housing? If it's to replace uni-joint bellows, then you don't need to remove the shift cable.
Unscrew that square piece you have circled, there is one on the other side as well. The cable just slides out.I need to rebuild the bellows and it is last step to take of the bellows. Can anybody guide me to disconnect the shift cable in engine side?
