- Jul 18, 2011
- 19,022
Greetings,
I could easily title this thread 'Here I go again . . .' another upholstery job. This time it is on the new-2-me boat . . . a 2016 Cruisers Yacht 338 Bowrider. The boat is only 5 years old and the cockpit seating is already in need of some serious work.
The backstory is that in my recent boat search, I encountered many fairly new boats that had issues. Gelcoat fading and upholstery deterioration topped the list.
It was a bit shocking that 5-6 year old boats would need such work, but I was sensing a 'new normal' where people buy new boats, beat the hell out of them for a few years, and then look to sell and start the process all over again with yet another new boat.
Anyway, because of the needed work, I was able to factor that into the price negotiations and the boat was ours.
There are 2 issues with the cockpit upholstery . . .
1) The main issue it appears that the wrong type of thread was used (probably a polyester or nylon thread) and it has disintegrated due to sun exposure. There are other areas where the thread did not wear well.
2) The choice of vinyl style used in the seating is suspect. Cruisers uses/used Spradling brand vinyl, which is a decent vinyl, but not over the top. The style was a textile-look finish, which seems to be a 'thing' these days. However, the textile pattern does not wear well at all and quickly discolors.
Here are a few pictures showing the issues. . .
We looked at another boat just like this one, except tan/white color seating instead of gray/white. Although the stitching was intact the discoloration was readily apparent. I talked with Cruisers Yacht Tech Support both before and after buying the boat to gain some insight to the issue and options for resolution. The boat is out of warranty, and I believe the PO tried to get the seats covered under warranty to no avail.
So, in re-doing the seats, I wanted to go more top-shelf on the materials and get away from the textile pattern in the high usage areas, going a bit old-school with the vinyl choices.
I also thought to add some color to the seating, as there was/is a 'Black Diamond' edition of the Cruisers 338 that had some red mixed in with the gray/white. It looked pretty good in some of the pictures I've seen, as per below. . .
The Game Plan . . .
Instead of Spradling brand material I plan to use Omnova brands of vinyl - Nautolex and Boltaflex are their common product lines.
I've been able to get the vinyl information from Cruisers and have cross-matched it to suitable equivalents in the Nautolex lines. The before/after vinyl choices are going to be:
White - was Spradling Begula 'Pure White' will be Nautolex Cetacea 'White'
Gray - was Spradling Simtex 'Plata' will be Nautolex Capitano 'Techno Gray'
Dark Gray - was Spradling Diamante (discontinued) will be Nautolex Beacon 'Lead'
Black - was Spradling Simtex Black will be the same . . . Not able to cross-match.
Red will be Boltaflex Colorguard 'American Beauty'
I will say that my 24 foot Formula had the Boltaflex Colorguard vinyl and it is probably the most durable vinyl I have ever seen . . . super fade resistant. The grain pattern is a bit dated though . . .
So far, I've estimated out all of the vinyl and it will be about 50 linear yards of vinyl material, along with an equal amount of 'sew foam' backing and 4 spools of Tenara brand thread (what is known as a lifetime thread - PFTE), which I used on my Formula re-upholstering. (Formula boats uses it as well as the Nautolex brand vinyl).
Next steps will be to . . .
1) set up my sewing machine (Consew 206RB-4) at the summer house where the boat is located
2) Order the Vinyl
3) Begin dismantling the seats from the boat.
Fun, fun, fun.
The Game Plan . . .
2) Order the Vinyl
Fun, fun, fun.
