matt167
- Sep 27, 2012
- 4,460
My boat in my signature was powered by a 1966 Johnson 40hp Deluxe, and previous owners had wired it as they saw fit, which was done right in some ways and not in others. They put in a disconnect switch, and half of their electrical bypassed it, but the motor used it at least. I never quite figured out how it worked until I de rigged the 40hp.. The disconnect switches the negative, but the power still came off the battery. That's why half of their electrical bypassed it. I added bilge pump wiring and aux wiring up to the dash when I redid the boat originally
Now that I have the new DF25A, I'm trying to clean this up a little, but I'm debating what to do. I bought a new 4 circuit Blue Sea Systems fuse box as that's all I think I need, and I have a 10 place negative buss bar, and I think a 10 place buss bar under the dash from the first time I fixed wiring ( installed bilge pump ).. Do I connect the negative side of the motor to the disconnect switch? The manual does not cover anything about a disconnect switch. I will terminate all positive connections that currently go to the battery, to one of the 4 circuits and provide a wire of adaquate size to go to the battery. Could I hook the disconnect between the battery and the negative buss bar? Leave the motor connections seperate from the disconnect, but everything else would go live by turning the switch
