Last night I got the gas tank prepped and installed. Put down rubber strips the vertical way so if water gets under my hatch it will run out the bilge.
The ones in the indent of the tank are cut so that a 2x4 will sit on top of them flush with the top of the stringer. I will screw into these pieces only so I have no penetration into my stringers or bulk heads. I then added some of the same rubber to the bottom side of these wood pieces and glued them in the PL. Should work out nicely.
Also over the last few nights I have been fighting with the sun deck cover and foam. This was very frustrating and it’s not as clean as I would like but looks decent. I didn’t really want the seam indent but ended up having to do it to get the cover to fit correctly, I guess it will kind of match the lower seats. I still have to tuck the right side but i was done for the night last night.
