transom leak
rickasbury
Master Chief Petty Officer
I have a 350 horizon motor with bravo lll with a transom leak. Took a friend to the ramp with a camera to see if we could nail down the source- he is a merc mechanic but does not work on boats at present. He says the leak is coming from the y pjpe, thinks its from around one of the bolts where it mounts fo the transom. I'm not convinced. I read on another forum that if I run the boat on muffs, if ahold leak info the bilge. Is that correct? Why would water be coming through the exhaust? Does the cooling water exit through that y pjpe? Also said if I fill the bilge with water and that is the problem if will also leak out fh
Bt Doctur
If it is the Y pipe leaking into the bilge the water will feel warm. A leaking Y pipe will leak when the boat is put in the water .
You exaust is water cooled at the riser/elbow. From there the exaust and water go down the Y pipe and out the transom
rickasbury
Thanks for the great info! It does leak as soon as it goes in the water. When I got back there on another trip, I thought I saw water coming in around where the Speedo and water pick up comes thru. I will run it on muffs and see what I have. Thanks!
Ayuh,.... The y-pipe is full of water, as soon as ya back the boat into the water,....
The motor needs to be pulled, to remove/ replace/ fix the y-pipe,....
alldodge
It could be the speed-o tube or shift cable. Raise the drive and have a good look at the boots.
rickasbury
I did replace all the boots as I was so sure that was my problem but could never find any holes- it needed to be done anyway. I will test it with the muffs on and see if that is it and go from there. Thanks for the replies and will update with a final solution..pretty cold here in FL so it might be a bit!
rickasbury
So, this has me thinking..the flange on the y tubes goes through the transom and then bolts up to the outer part of the transom assembly right? So how is that exposed wood of the tansom protected?
Bt Doctur
When the factory cuts out the hole they never seal the raw wood, they just bolt the housing on
rickasbury
So if the flange goes through the reason, all that exposed wood is just sitting in water which I would think eventually cause it to rot?
alldodge
The hole is cut and the transom assembly seal keeps all the water out. If water leaks into the bilge from other areas high enough to reach the bottom of the hole, then yes the water can start penetrating the wood if its not sealed.
Some manufactures paint the wood before the transom assembly is installed and some do not
rickasbury
Wow, I would sure hope so! If indeed this is my problem, mine will be sealed. I store it on a trailer and I'm sure by the time I get this fixed it will be all dried out.
Thanks,
Rick Stephens
Thanks,
When most of us do a transom repair, when we cut the keyhole out we then basically fiberglass the cut edges making everything as sealed as possible. Pretty much every factory keyhole I have seen the bolt holes were bare wood. Mine own current boat the whole keyhole edge had a pretty second rate paint job on it. Even that isn't what got my transom wood wet though, years of not very well sealed in screws for the pitot and transducer for the fish finder steadily leaked enough water to start rot in the lower part the transom. There ain't no such thing as a wet transom drying itself out.
rickasbury
Thanks Rick, I suppose your right. I have not figured any reasonable way for me to set that motor back to get access to the y so likely will have to have someone else do it. I bed property I can Pak the boat and take care of it...
scoflaw
Ensign
I wouldn't jump to any conclusion about the source of the leak. If it's the y pipe it will leak on the flusher in the driveway. My last 2 boats had a leak at the transom seal. Gave them a quick fix by running a bead of 4200 around the perimeter of the transom assembly.
rickasbury
Thanks, I know my options for this leak are "open". I hopefully will get it home this weekend and give it a try...
rickasbury
New Thread for my Transom Leak!
Figured I would start over and lay out the whole long and sad story. I wish I had an extra 5 grand laying around that I could just take the boat to the shop and say "fix it". Just not my nature even if I did.
My boat is an 05 Rinker 270, 5.0L Horizon MPI with bravo III. Has around 300 hours on it or so the meter says.
Water in the bilge has always bothered me. It seemed sometimes it would have some, sometimes it would not. I THINK the times not were at first just when we ran the boat for the day and did not use the A/C. Here in FL, when you run it in the summer time it sure seems to generate a lot of water. So, kind of went back and forth on whether water should be there or not and where it was coming from. Summer before last things seemed to have changed for the worse. I had a coupler go out. Now the only recollection of me striking anything was months before it went, I came around the corner in the river I boat most and I think I hit a submerged tree that had fallen over the bank. I was not going real fast but I felt it, seemed to be tangled, had to back up to get untangle and went about our boating day. There some scratching of the out drive but nothing major so did not give it another thought until months later the coupler went.
So, I get the coupler repaired and now it seems I have a lot more water coming in the boat than before. So I am on a mission- I bring the boat home and put powder around the thru hulls and use my fake lake to put pressure from the out side of the boat and get nothing. Get nothing when I run the boat on the muffs. Keep using the boat,...sometimes it has water in the bilge and sometimes it does not but then it also starts to really stink- I come to the conclusion that my waste tank must be leaking but it does not seem to all the time- crack up high from pumping out and sucking down the tank? Eventually, I pull the tank out and low and behold, about an inch up from the bottom there is about a 1/8" hole in the tank, perfect hole not a split. Apparently, TP would clog up the hole and then as stuff moved around in there it would un plug and leak and then as it leaked down, would plug up again. Sorry if your eating dinner reading this. So, I pulled it out, put a plug in it, put some glue around it and that seem to solve my problem of leaking, I thought. So, at the marina, and the bilge pump comes on during the night. Never really did that before other than my leaking waste tank and that problem fixed so where is the water coming from. I had a week off and left the boat at the marina and was determined to see where it was coming from. I eventually did see a trickle of water, not a lot but a good steady trickle coming in and figured, great, must be the bellows. I was getting ready to start a new job, lots of unknowns so we put this on hold for a bit to get life smoothed out. After about 3 months, I went ahead and ordered all the bellows parts, gimbal bearing and new seal kit for the drive. I have a good friend that was a former mechanic/service manager for a couple of shops around town that had all the tools. Only thing that really gave me a fit was that bearing. I broke the merc tool getting it out, stripped the threads. Ended up with a slide hammer from auto parts store and eventually got it out and back together. Figured all my problems are solved- except it still leaks and it leaks worse. I put it in at the ramp. The water seems, as near as I can tell coming from the area around where the water pickup tube comes through, the speedo and the trim wires. My friend got down there on another trip to the ramp with a little camera he stuck down by the Y pipes and he thought it was coming from there- Like maybe it had rusted out and got knocked when the motor went back in from the coupler and cracked it or something. I brought the boat home today and ran it on the muffs and no water is in the boat. I put my phone on a a selfie stick, not sure what I thought I would see as there was no water in the boat anyway, but saw nothing.
Just below the plastic piece where the speedo tube fitting is, you can see the metal is stained with water as it collects on the flange there. It is from that area. I guess my delima now is, is it from one of those parts coming through the transom or did I crack the transom assembly and lose the seal and now is leaking, and worse after banging the hell out of that bearing to get it out. The only other test I can think of to do to confirm it before shop time is- and one of the guys on the forum fixed his leak this way but I don't see it as a safe even semi permanent solution-run sealant around the the outer gimbal ring/transom and see if it stops leaking. I suppose if the gimbal ring is cracked, it would still leak it and if those other parts mentioned (speedo, water pick up and trim wires) are leaking on their own it would still leak. The starter is so low on the motor, I don't think I can put any amount of water in the boat on land to see where it might be leaking out.
I really need to get this fixed and back to boating- been side lined for 8 months now. Any other ideas????
jbcurt00
Please don't start multiple topics about the same subject. Creates duplication of effort.
merged
alldodge
Get something like a screw driver and try to move the speed-o tube. Don't use max force but more then a little. If the fitting moves, its cracked
Disconnect the speed-o tube off the drive, tape it up and tie out of the way. Check for water.
If the water is coming in above the speed-o then its probably the upper steering pin seal
IMO, if the transom assembly was cracked you need to pull the motor, and if the transom assembly seal is leaking, your transom is soft and in any case you have to pull the motor.
