Has anyone used a pinstripe remover such as this?
FrankyB
Napa paint swears this will easily take pin striping and adhesive off with no damage to gel coat. Anyone have experience using a similar one?? Frank
Grub54891
Yes, they work well. Used them many times. As with anything, don't hold it in one spot to long, it may burn the gel. Never had that happen, but I err on the side of caution.
CraigBarnard
Never used one but I have sold a Ton of them.
Autobody guys absolutely love them.
They work extremely well. Been told the best product for pinstripe etc removal.
further
Yep took all the 18 year old pinstriping off my boat last year in a snap. Use some acetone to clean up the residual glue.
Davetowz
Neighbor saw me using razor blade and loaned me one. Only way to remove pinstriping.. awesome tool.
I've used them and razor blades. For me, both work
fishin98
They work great, as mentioned before...do not hold in one spot for too long...acetone for clean up afterwards works great.
Bow Guy
yup they work great.. once you get the drill speed right and the nack it works great!!
bruceb58
It's a real good way of ruining a drill since they aren't designed for side pressure.
Davetowz
If wearing out the drill is a concern, buy a cheap drill from harbor freight to abuse. Only reason to buy tools from there! :)
FrankyB
Thank you everyone for your responses! I used it and I can happily say it produces awesome results. I stripped all of my pinstriping off one side of the boat in less than 30 minutes! I couldn't imagine doing that with a heat gun and a razor blade. For others considering this... a few lessons I learned: get the rpms and the wheel direction right else the wheel will become difficult to handle and will jump a lot. very fast is not necessarily the best of choice versus a nice moderate speed. I do the other side next weekend. :)
\Frank
