artfan1
- Aug 14, 2015
- 73
OK, I would like to officially join the I hate grinding fiberglass club. This part is, without a doubt, the most miserable part of the process so far. For me, the part that I have the most trouble with is having to retrain myself to work with limited visibility and mobility. I havent experienced any itchiness so far because I am so well covered in Tyvek, respirator and gloves but inside of my encapsulated space it looks like it snowed heavily.:smow: I just keep thinking of next phase where I get to play with the new materials.
I still have lots to do but I wanted to check on a couple of technical points.
What exactly is my goal here? I mean, beyond the part where I remove the grungy, dirty fiberglass and grind down the seams and corners from tabbing, technically what is the required point where a surface is prepared?
Please note, I am NOT asking this because I am wanting to rush, or because I am trying to cut corners. I am asking this so I know how perfect all areas of the surface have to be.
Here are some examples of what I am wondering about. (Sorry I dont have any photos to go along with these. Difficult to do at this stage).
1)- The floor of the hull has a layer of chopped strand. And yes in many areas, it is porous and dirty. I know that all has to go. But in large areas, once I start to sand it, the area becomes very smooth and clean although you can still see the light lines of the chopper strand. Should I remove all trace of this?
2)- Just like the floor is covered with chopped strand, the sides are covered with a layer of roving. Maybe that roving is part of the hulls structure, I don't know but because it's dimpled it's full of that creamy white stuff. I am grinding it down to the point where it is flat and all of the creamy white material is gone. Do I remove all traces of the roving even after its smooth and clean? Some areas its hard to tell if I am seeing the fibers from the hull or if its roving.
3)- Areas above the hump where the bottom meets the side (the chine?). It dips down before it meets the side creating a small gutter were epoxy pooled rather thick. Once the old layer has been removed I can see this pool of epoxy, but its clean and clear of any dirt or pits. Can this be left there or do I need to carve it out?
Lastly, what IS that white/cream colored stuff that is painted all over the surface of the inside of the hull? Just curious what that is exactly. I referred to it in the past as primer or gel coat but Im sure thats wrong. It is very thick in some areas and thin in most. It looks like it was painted on because I can see brush marks on the top edge. Its very nasty stuff.
I know that when grinding the old away, we are prepping for the new. I understand that the physical layers of buildup need to be removed so that compartments and other structures can be replaced properly. I also understand that contamination is a problem when adhering the new materials. But once an area is clean and level, when do I stop?
