Mark72233
Ensign
Thread starter- Joined
- Jul 11, 2014
- 926
Cool and thanks. The side windows won't matter because they are up in a channel and out of the way. I will have to cut off the 8 bolts that hold the main 2 pieces in place because they hang down into the cuddy cabin which already doesn't have much head room. I got a 36" piece of 7/8 stainless tubing I ordered for the bow rail because 3 of the rail supports were apparently replaced at some point with aluminum tubes and they of course don't match and were corroded from I guess being in contact with the SS parts. Anyway cut it into 3 pieces and replaced those. Scrounged up all the pieces of teak trim and brushed them clean and once they dry I got teak oil to put on them. I also managed to come up with a way of fixing the broken bifold louvered doors. The base of both side and one at the top where the dovetailed pieces are cracked, broken and pieces missing. I should have taken some before pics. Anyway I had found some teak blocks on eBay that are about 15" x 2" x 3/4". I cut them in half length way so I had 2 pieces 15"x 2" x whatever half of 3/4 is. Glued them to the front bottom covering the broken areas and screwed them from the back and bang. Doors fixed and look good and almost original.
Once everything dries up I will coat it with the teak oil and bring out the beautiful teak wood look.
