Re: Which model rules iboats?
Pics of the 'itchy' boat (Capri 17) can be seen here at a former post:
http://forums.iboats.com/showthread.php?t=414139
I'm still ordering parts and finishing up the deck.
The Starchief has been here for a few years, it too will be due for a deck soon.
This pic is old, it was the one the seller used on CL back when a buddy of mine first found it. He bought nearly the identical boat around the same time, both from CL, both within a few miles of each other.
I've since tossed the older motor in favor of a 1990 115, which actually runs stronger than the old motor did. I sold the old motor pretty fast on CL, even without a working tilt and trim. The two fold down seats are gone too, in favor of two newer white plastic seats. I've been knocking around ideas on how to rearrange the floor plan a bit. Right now it's got two seat boxes with short pedestals mounted on each box. Each seat box houses a 12 gallon fuel tank. The transom is original, but still rock solid, the deck has some well worn spots between the seats. Most likely from water getting into the seat boxes and not draining well. After this season, it's getting redone.
