TOMCAT1234
Thread starter- Joined
- Jun 7, 2010
- 2
I have a 1977 Johnson 115 that will not pump water on startup. You have to open it up wide open in nuetral a few times and it starts to pump fine. It will pump solid until you turn it off, and you repeat the ritual. I thought the pump may be bad, so we replaced the pump, added guide tubes to make sure the water pipes were in the holes, and it still does the same thing.
Once you get it pumping it pumps great and I can run up river for as long as I want, until you kill it. It is a pain running trot lines and having to do that at every line though.
Thanks for any help.
