mydeckisbrokt
- Oct 31, 2008
- 38
Re: New to iBoats with my 71 Glasstron
Rub rail = off, ty!
I ran into what I beleive will be the last demolition problem here. Seperating the cap from the transom and the transom from the boat. where the splashwell is, the rear section(vertical part) is well attahed to the transom, and the top is bonded together w/ something, but I am unsure what something that is. When I grind, it glistens and leaves white powder everywhere. My grinder is only a 4" and wont get all the way through.
I was thinking of cutting where the splashwell meats the transom, and glassing the spashwell to the new transom once installed. I cant see any way of getting it seperated w/ out doing some damage, so I am reaching out to find some help.
Thanks in advance.
It should slide out, but you may have some luck pulling it out if you use a hair dryer to soften up the rubber. The aluminum rail is going to be either riveted on or held in place with stainless screws.
Rub rail = off, ty!
Thanks in advance.
